Build indycole's 2016 200 Series Build and Retrospective
Secondary Battery System and Electrical
This was a fun project that required some planning, though nothing was particularly difficult. I wanted a deep cycle battery system to power camping accessories while the truck is off and also for peace of mind to help start the main battery (though I have a micro starter for that purpose).
I decided to go with a battery system based on the Blue Sea ACR. I didn't really care as much about controlling the system from the cab (though I still can if I want) and also thought it was a cost-effective approach. So far I've been very happy with the system.
First things first -- I installed Slee's primary and secondary battery trays. Only 3/4 of the bolts could be used on the primary tray due to some changes to the fender on the 2016. No big deal -- it's not going anywhere. The secondary battery tray install was a breeze. I went with the Odyssey Group 35 deep cycle battery. It seems like a good battery but I wish it had accessory posts.
Let's run through all the items on the secondary battery circuit:
  • Primary Battery via ACR
  • ARB Compressor (though will mostly be operated while the truck is on and the batteries are connected)
  • ARB 50qt Fridge/Freezer
  • HAM Radio
  • CB Radio
  • Battery Monitor
  • Auxiliary 12v Power Outlet in Cargo Area
  • Auxiliary USB Power Outlet in Cargo Area
  • Roof Lights (Light Bar + Camping Lights on Front and Rear)
  • Dashboard Switches
There were also some future items that I wanted to plan for:
  • Charge via Solar
  • Winch (this would connect to the main battery but I still wanted to take it into consideration)
  • Interior Cargo Lighting
Here's what I ended up implementing given the requirements above:
  • 0/1 battery cable from the secondary battery to the ACR through an ANL fuse. This cable follows a short path from the battery to the ACR mounted on top of the cruise control fuse block (I think???). The ACR is screwed into the top of the block and secured with a rubber tension strap.
  • 0/1 battery cable from the ACR to the primary battery through an ANL fuse. This cable is run along the firewall.
  • 0/1 battery cable from the secondary battery (-) to the primary battery along the firewall. I originally had this running along the radiator and decided to move it to the back for safety purposes.
  • There is one 60A circuit breaker and one 80A circuit breaker screwed into the fender sheet metal just behind the air filter assembly. 6 awg battery cable runs from the 60A breaker into the cabin through the passenger side firewall grommet. 6 awg cable runs from the 80A breaker to a Blue Sea fuse block on a relay board I built on mounted on top of the driver side fuse panel behind the battery.
  • I ran the 6 awg cable from the from cabin to the cargo area through the door jam. In the cargo area, the cable goes into a Blue Sea fuse block where I power the battery monitor, refrigerator, cargo auxiiliary outlets, and the radios. The radios are connected directly to the fuse block, but everything else goes to another Blue Sea fuse block installed as part of the ARB drawer fit kit where I installed a Blue Sea panel with 12v outlet and USB outlets. There's also flush-mount anderson power pole connector for the ARB fridge.
  • Knowing I'll likely end up with more gizmos switched from the cabin, I built a relay board that handles six relay circuits. I'm currently using 3 circuits for the air compressor, roof light bar, and roof camping lights. I'm also running 12v/gnd into the cabin for the switches but have considered a fuse block under the dash in the future if needed.
  • There's also a fuse block on the roof for roof rack lighting. It's housed in a project box, uses gland connections on each side, and currently has the lights on two circuits: 1.) the front light bar, and 2.) the side and rear camp lights. I ran 10 (or maybe it was 12) awg for the ground and 3 x 14 (or maybe it was 16) awg wires to the roof. The extra wire is there for auxilliary power to run into the RTT for charging devices.
Lessons
  • I've yet to hook up the battery control switch that comes with the Blue Sea ACR. I haven't needed it yet though I have made use of the manual switch on the ACR while working on the truck.
  • Maybe I went overboard, but I don't regret the decision to put marine grade sheetshrink and the fancy red/black loom over the cables in the engine compartment.
  • If you do an excellent job placing the components and measuring, you could consider having Genuine Dealz make your cables.
  • I had to route cables under the paneling between the front and second seats as it would not fit through the channel. You can't tell, though.
  • It may have made more sense to run signal wires and a single power line to the roof. Meh.
  • A hydraulic crimper is a must for the 0/1, 6 awg, and even the 10 awg terminals.
  • I'm close to running out of blank switch panels in the cabin. Perhaps I should have gone with a more scalable switching solution? That SPOD thing?
  • * I picked up a lot of special tools for this project: ratcheting wire cutter, hydraulic wire crimper, a heat gun (my tiny culinary torch didn't do a good job), a butane-powered soldering iron (there's no power available in my condo garage), anderson power pole crimpers.
  • * The National Luna battery monitor in the rear is provides enough information for me. I don't have anything mounted in the cabin.
Sources: Slee (Battery, Battery Trays), Blue Sea (ACR, Fuse Blocks), GenuineDealz (Battery cable, wiring), Amazon (marine grade heat shrink, hydraulic crimper, marine grade spade connectors, other tools), Equipt1 (battery monitor)
Your wiring is elegant and your system is well thought out. Your engine bay is as fun to study as some art. :cheers:
Great thread! Keep us posted! (Also on any 8spd issues you may have).
Thanks for your thoughtful posts. Really liking your truck. Are you planning on a Slee rear bumper? I been waiting for them to start production.
Yeah, I really liked what I saw of the bumper when I visited the shop last summer. I'm hoping it's available before next summer though am content to continue scraping the plastic bumper for a while.
Awesome thread! It is cool to see someone putting a 2016 through the paces. You have a really good looking Cruiser as well :)
My upcoming Saturday morning project.
Escape Gear Seat Covers
What started as a simple search for some kind of device to keep the back seat safe and clean from the dog, eventually led to our ordering Escape Gear Seat Covers from Equipt. The covers arrived about a month after placing the order (earlier than expected!). The covers arrived in a nice duffel bag that I will most certainly be reusing. The worksmanship is outstanding.
Installing the covers took a couple hours. I'm not 100% I cinched the rear seat covers correctly but the fit seems to be work. I'm pretty happy with the results though I need to spend a bit more time on the headrests.
Lessons
  • Escape Gear does not have a color that matches the Terra interior, so I went with the grey as opposed to the khaki. I think the color is fine... matching the leather was never a huge priority for me.
  • The only trick to the install was figuring out how to detach the bands that secure the bottom of the front seat back panels. Just feel around for a band under the seat and you'll figure it out.
  • Iteratively tighten the buckles until you're happy with the fit.
  • The quality of the covers is quite impressive. There are still areas where the seat shows through, but I don't know if that's intentional or if I still have some fit adjustments to make.
  • Originally, I was going to get covers that worked around the monitors; however, I decided to get the normal ones and to just remove the large screens. I put some foam in place but am thinking about machining something to fill the void. Just not sure what material or finish to use.
Sources: Equipt1
Beautiful rig, great mods and a clean installation! Add to that - the challenge of working in a parking garage!
Its a shame to cover those gorgeous seats - but totally understandable!
Which dealer did you buy it from in NC?
I'm curious if you can still feel the heat come through on the heated seats with the covers on. I'd like to protect my seats as well, but I use the heated seat function about 3/4 of the year.
It will work, no problem!
I concur. Seat heaters and coolers still work with no issues with the Escape Gear seat covers in place.
I purchased mine for the same reason, to protect the leather from the Golden Doodle, my wife's side kick she goes every where with. She looks just like yours @indycole! You won't be disappointed... with the seat covers.
Is the material soft on those seat covers? I'm contemplating buying OEM cloth seats from a 200 on australia's ebay. I love everything about the 200 but I hate leather seats.
The cotton canvas is breathable and comfortable -- no complaints after one day using the covers :) If I were in your position, I'd totally give seat covers a try before putting in cloth seats.
I think the Escape Gear canvas is very similar in texture and feel as a Carhartt canvas jacket or pants I grew up wearing on the farm. May be a little thicker material.
Eezi-Awn 2000 Series Awning
I received the Eezi-Awn 2000 Series 2.5m awning from Paul at Equipt1 just a few days before our long-weekend trip of meandering around the Eastern Sierra and Death Valley. Due to the width of the James Baroud tent, I ended up needing to fabricate my own brackets to mount the awning in conjunction with the Eezi-Awn mounts. It was a good excuse to use the mill, welder, and powder coating equipment at TechShop in San Jose before it closes at the end of the month.
I decided on the Eezi-Awn based on a number of factors. Most importantly, it came in black :) I also liked the ease of setup (not that other awnings I've used -- Rhino Rack and ARB have been that difficult), the hard shell case, and the optional awning walls that are compact from a storage scenario and easy to set up.
We used the awning at Eureka Sand Dunes last Saturday and also deployed it for some general relaxation along other parts of the Eastern Sierra (Mammoth, Alabama Hills). It did not disappoint.
Sources: Equipt1
Lessons
  • I have around eight inches between the bottom of the James Baroud Tent and the top of the rear passenger door. I wanted to keep the tent centered on the roof which means the awning needs to be tucked-in below the tent. I also decided to fabricate my mounts prior to receiving the awning primarily to have the mounts ready for the awning's arrival since we had a trip planned. I used some measurements from Equipt's website as rough inputs to designing my custom mounts. Everything went as planned except for two things -- 1.) the Eezi-Awn latches open upward, requiring an extra 1.5-2 inches than I'd planned, and 2.) the Eezi-Awn mounting brackets extended too far down, causing a collision with the door. What were the implications? I ended up not mounting the awning exactly as planned, but trimmed the Eezi-Awn brackets in the mill to eliminate the collision with the door. Door clearance is no longer a problem, though I now have to manually lift the awning case if I want to open the passenger side doors while the awning is deployed. Not a huge deal, but not exactly perfect, either. There's no way to fix this without mounting the latches somewhere else on the awning.
  • We're thinking of replacing our shower/changing room tent with the RecVee awning walls.
Awning brackets pre sandblasting and powder coat
Awning deployed
Wife's LC shirt (and view of the awning while closed)
Easy driving through Alabama Hills
We stayed at a hotel in Folsom on the way home and woke up to this. All our valuables were inside the hotel and the drawers were locked. They didn't take anything... looks like they just pulled the dog's blanket on the floor up and were disappointed to only find a shovel.
GVWR Concerns
On a whim, we stopped by a truck scale on the way home (no pun intended). The truck weighed in at 3360 lbs on the front axle and 4000 lbs on the rear for a total of 7360 lbs -- a mere 25 pounds less than our GVWR. Further, that was without us in the vehicle, a half tank of gas, and only camping supplies and luggage for a 4-day trip. For 1-2 week trips it's not unusual to have another 500 lbs between people, luggage, firewood, fuel jerry cans, and water... and we're relatively light/organized packers.
How concerned should I be? Does my aftermarket suspension buy me any extra weight capacity? I will say that handling has not been a problem at all on or off road (especially compared to my old Yukon when loaded down). I've gone through the tire pressure exercise using the process that @gaijin has graciously explained in other threads, and by my calculations the tire pressure should be 54 psi cold based on an incramental 1780 lbs over the stock load -- yikes. I'm currently running at 46 psi cold based on a prior weight estimate before visiting the scale.
Hidden Winch Mount
My next project is determining the feasibility of making my own hidden winch mount. I know that there are some downsides to removing the factory crash bar though I suspect that'd be the case with any aftermarket bumper aside from the ARB. I simply desire the peace of mind of a winch without the downsides of a full front bumper (though I'm aware of the safety benefits). Some ideas for the winch mount:
* Once piece welded out of all 1/4 flat stock aside from the mounting brackets
* I'd consider borrowing the clevis nut and threaded rod idea that both ARB and TJM use for a bit of extra support
* Fit at least a 9.5 or 10k winch
* Still provide requisite support for front bumper (not sure what this means as I haven't popped off my bumper yet)
* Attach to ARB skid plate
* Considering integrated, shielded toe hooks but I wouldn't want to run the front member from a bad tow... this may not be a good idea
* Elevated winch mounting plate with recessed bolts so that the winch bolts aren't scraped/broken while wheeling
I've committed to at least designing something but I don't know if this is actually something I'll take on.
Regarding GVM concerns... We were having another discussion of this in another thread...and my thought was that it's likely the suspension that is the weak link, or danger point, since too much weight means bottoming out, and unsafe handling due to excessive lean, etc.
With that thought in mind... I found this Australian offering that seems to back that idea.
They offer a "GVM Upgrade Kit"....which is essentially heavier coil springs and other suspension components. It makes the heavier load LEGAL, which is interesting...because its components are really simple, and essentially what we all do when installing heavier springs/coils and shock absorbers, etc.
KEY:
They even include a legal REPLACEMENT door sticker that lists an additional 500kg...
That's an ADDITIONAL 1,202 pounds to the LEGAL GVM for the 200 in Australia.
If this satisfies the requirements there, it would lend credence to the idea that it's largely about appropriate suspension...and that we're on solid ground taking similar measures. Legality? I know know. I've never heard of a private vehicle being cited for this...
Here's the link to the product offering:
GVM Upgrade Toyota 200 Series Landcruiser
