Impex is LEGIT 4 new AHC globes. Door To Door from Japan, less than 2 weeks
So I have a questions before ordering...
I have read all the comments about what a big difference the Globes make and really make the ride super compliant. My 2005 LX470 that I just recently bought with 200k on the clock, does ride a bit bumpy and it's noticeable. The AHC system itself works perfectly fine, it lifts and lowers just fine.
So the questions are:
1. But how do I determine if my Accumulators/Globes are actually bad before I order them?
2. Based on the above, is it worth trying to just bleed and flush the AHC fluid first instead of jumping straight to replacing the globes?
thanks.
thanks.
They’re more than likely bad. Double check by performing the graduation test and that’ll let you know if you only need a flush.
Need clarification on the above...
I see the fluid level going up and down changing from lowest to highest position ... perhaps about 1.0-1.5 inches.
If the fluid level is changing as such, but ride quality is jumpy does that mean one should change the globes .... or first try to change the fluid?
Search the graduation test but one inch is probably only 5 graduations. A healthy system will be about 14. You probably need globes.
thanks.
Guys, if your globes have never been changed......odds are excellent you have one or more that are in bad shape or about to be. Globes have never been more affordable. Just get them.
I have 8 graduations on mine, but when I changed the fluid I definitely had lots of bubbles coming from one globe, so most likely its gone. It rides alright, and I have no frame of reference on what good should be, but I'm changing the globes. Worse case I get another 200k miles worry free from them, best case the ride gets even better.
I searched for Graduation Test... there are a lot of threads but not finding one that specifically the procedure for this test. Also looked in the FAQs but no luck.
Can someone point it out please?
Park on a level surface and while your AHC is in low, mark your AHC reservoir where the fluid is (should be higher than at normal). Repeat this, but while the car is in high mode. Now count the graduations located on the reservoir that differ between the two modes.
Good practical description by @TexLexican -- I have posted similar information previously but buried in multiple other posts, searching "Hi/Lo Test" would reveal.
The FSM guidance is a bit cryptic -- see attached -- same for LX470 and LC100 (where AHC is fitted).
It is hard to find because it is filed under "On Vehicle Inspection" for the Damping Force Control Actuators, with the heading INSPECT GAS CHAMBERS which is FSM-speak for 'inspect globes'.
The test simply measures the volume of fluid displaced by the height movement in the 'shock absorbers' plus the push-back from the 'globes' at LO versus HI (AHC pressure is lowest at LO, because more weight is carried by compressed springs and torsion bars, less weight carried by AHC system).
Assuming that nothing is out of order, the displacement from the 'shock absorbers' is constant each time it is measured at "HI" and "LO", so long as the vehicle height at "N" is the same whenever/wherever the test is done. The test should be done on a level surface (think garage or similar, not in the street). Cross-levelling the Front should be done first. Front and Rear AHC pressures also should be in the correct ranges at "N" height for the test results to be comparable with the FSM recommendations. AHC Fluid should be in good condition -- if polluted with gas and/or moisture and/or debris, then readings can be unreliable, particularly if the AHC Fluid contains air, or nitrogen from failing 'globes'.
The idea is to repeat the test over time (say annually over 10 years) under the same conditions each time. Then it can be assumed that the displacement from the 'shock absorbers' is the same each time, and, the declining differences in the number of "graduations" observed at the AHC Tank from time to time in each test is due to the declining push-back from the 'globes'.
Over time (years) progressively fewer "graduations" will be observed, as the 'globes' slowly lose their nitrogen pressure from behind the membranes. This also will cause damping and 'ride comfort' to deteriorate as the pressure in the 'globes' slowly declines.
Declining nitrogen pressure in the 'globes' means that damping (which is done by the Damping Force Control Actuators controlling the rate of fluid inflow and outflow) becomes less and less effective.
Note: The 'globes' by themselves are not 'shock absorbers' but actually are gas springs. The 'globes' combined with Damping Force Control Actuators are the actual shock absorbers in an AHC-equipped vehicle. The items called 'shock absorbers' in an AHC-equipped vehicle are simple hydraulic struts used to adjust the vehicle height in real time all the time -- the auto levelling function alias Active Height Control (AHC) -- as controlled by the ECU responding continuously to the Heght Control Sensors and the driver instructions via the height selection switch at the centre console, and deploying the AHC Pump and Levelling Valves as required.
When the 'globes' are new, this test under standard conditions should reveal a difference of around 14 graduations between HI and LO.
When the test result declines to a difference of 7 graduations between HI and LO under standard conditions, the FSM recommends replacement of all 'globes' to restore damping performance and 'ride comfort'.
The limitation of this simple test is that it gives an outcome indicating the condition of the four 'globes' as a whole. It does not distinguish between the individual 'globes'.
Here are the fluid levels at Low, High and Normal. The difference between low and high is about 5-6 graduations. Looks like it's time to change the globes!
Yes -- 'globes' are way past their best!! Vehicle is 2005 LX470? -- If so, and if this is the First Replacement, it is no surprise after 19 years.
Front LH & RH: 49141-60010 -- order two of these
Rear LH & RH: 49151-60010 -- order two of these
You may want to check and compare price, availability and willingness to deliver from:
Japan
IMPEX JAPAN — online new genuine spare parts shop - https://en.impex-jp.com/
UAE
https://partsouq.com/
Singapore
About us - https://www.megazip.net/information/about
Japan
Genuine Japanese Car Part Imports - Amayama - https://www.amayama.com/en
All of the above are reputable and reliable.
Some eBay sources may be reliable.
** Sometimes these outfits decline to air-freight pressure vessels from Japan.
While placing order the IMPEX website is asking to agree to the following terms that means they will not refund if the items falls in this category.
I would assume none of us here on Mud have had any issues with IMPEX shipping the globes out.
Are the globes pressurized?
Did you guys also had to agree to these terms or is this something new?
We cannot ship item contains the following materials
  • explosives, such as airbag modules (as well as seatbelt assembly);
  • compressed gases, such as spray paint, and gas filled suspension parts (gas filled shock absorbers, etc.);
  • flammable liquids, such as automotive oils and lubricants, paint, gasoline, and oil filled parts (oil filled shock absorbers, engines, etc.);
  • flammable substances, such as matches, etc.;
  • oxidizing substances, such as peroxides;
  • toxic and infectious substances, such as agricultural chemicals;
  • radioactive materials;
  • corrosives: batteries.
Please note that in the aforementioned cases, cancellation of the order will not be accepted. Please make sure the items you are about to order do not fall under these restrictions.
I had globes sent from Impex a couple months back (Japan to Ohio). Zero issues.
The link below is a story on IMPEX shipping to Australia:
It might be different shipping to USA -- so local advice or concensus from people in USA would be more relevant to you -- or contact IMPEX directly for clarification.
The words in the IMPEX computer-generated response to you are a worry -- news to me before I saw the above link!
It might depend on whether the package is checked at either end by whoever checks exports and imports or whoever has to sign off on the package? If so, the above words are saying that the risk is yours, not IMPEX.
To answer your question: Yes -- the globes are pressurised with nitrogen as illustrated in my previous post. If the 'globes' are unboxed, it will be seen that this is printed very clearly on the actual 'globes' -- see pic below.
Not meaning to rain on your parade -- this situation seems to be a recent development at IMPEX.
I had this situation years ago with AMAYAMA (also based in Japan), so I used MEGAZIP in Singapore because their price was better than PARTSOUQ in UAE at that time. Prices vary a lot -- all of these outfits are consolidators and don't necessarily hold their own physical inventories -- their prices at any time depend on their buying price from their range of sources. There is huge worldwide trade in car parts, and participation usually is at the buyer's risk in return for the better prices.
I saw the same warning last month, but no issues shipping to Texas.
Impex - not just for AHC globes. I've got an order for a couple of JDM front corner lenses (clear) and front diff bushings, etc., coming. It was not much more to order the whole support arm structure(s) than to deal with trying to get the bushings out of the old, so I went that way. I will say I had to wait a little while for them to get something in stock - one part hung up the whole order - but it seems they did finally receive that in their shipping warehouse and it'll be here in a few more days. Just like with the AHC globes I ordered a couple years ago... WAY less expensive than buying through US domestic channels. If you have the time to wait, I think they're worth it.
Just as a data point, my truck and globes have 327K on them and I get 13 graduations from Lo to Hi in the reservoir. My truck has new OEM rear springs with spacers and adjusted torsion bars, and Techstream shows the correct AHC system pressures.
As much as I'd like to buy new globes, I don't think I'd see any difference. So, not all old systems need globes (apparently) just due to time and age.
Check the date code on your globes…
I’ll bet they have been replaced at some point.
So Im trying to order the globes from Impex. When I Put in the part number 2 options show up for the same part. A Toyota one and a Lexus one. There is a $20 price difference which adds up when you are buying all 4.
Should I just get the toyota ones for my LX? Is there a difference?
Thanks!
So Im trying to order the globes from Impex. When I Put in the part number 2 options show up for the same part. A Toyota one and a Lexus one. There is a price difference which adds up when you are buying all 4.
Thanks!
I ordered these for Dad's LX and they worked just fine, not sure I knew there were 2 part #'s at the time ....49151-60010
