Howdy everyone-
I have just heard my 76 fj40 run under its own power for the first time in over a year. It is/was a good feeling.
However, I am having a heck of a time getting the timing set. I have swapped an electronic ignition in from an '85 fj60. Here is what is happening:
The engine starts and runs on its own but only on with the choke all the way out. And it runs a bit rough.
When I attempt to put the choke back in the engine sputters and stalls.
I did let the engine warm all the way to opperating temperature.
Here is my delima: To get the engine to fire. I have the rotor pointed more at #5 Cylinder than #4, pretty much in between the two. To get the engine to run I must rotate the distributor ALL the way to the limit in a counter clock-wise direction. It will stay running at that postition but I have no more adjustability. I cannot see the BB or the TDC mark with the timing light.
I have started everything at TDC on the flywheel and on the compression stroke. Even as I scroll through the entire range of the timing light advance I never end up seeing either the BB or TDC mark.
What am I missing or doing wrong, I am really stummped. Thanks for any advice.
Drew <><
Drew <><
