Hello forum, I haven't been on here for quite some time, but have been doing research into the issues in the thread title on the forum, and downloaded a FSM.
Firstly, my LC was sitting for over a month and I took the battery out to recharge it and put it in the other day. It idled really low when I started it (Sits around 200 rpm) I read in another thread it could be caused by the throttle position sensor being out of wack due to the battery being disconnected and the ECU being reset. I did what was mentioned, which is leave the ignition on and press the gas pedal down a couple times and then started it but that did not fix the issue.
Is the only option now to get the sensor tested for proper voltage/resistance readings? Or should I take it to a dealer so they can use an OBD scan tool? Where is the sensor located exactly? I couldn't find a diagram in the manual for its location, just a section on how to test it. Could I maybe just adjust the throttle cable to increase the idle speed?
The oil pressure gauge also gives no reading, even when revved up. I checked the oil level and it was at the max level. I read it could be as simple as the oil pressure sensor being disconnected or corroded which I'll check on soon. If its connected and not corroded what can be a possible cause for no oil pressure reading at the gauge?
Thanks for any advice or help!
