Just cut my original can open! Drilled out the BB and need to get some charcoal. I've been running the VC120 for the past couple of years with no issues but would like the original can back in there. Thanks for the tech in this article!
Good question. I forded a river 4 times that weekend deeper than the frame where the tube is housed. I surmised the venting is so gradual at this point, I didn’t worry. I have had no problem as of yet. The 2 hour drive home didn’t seem to reveal any problems.Is there any risk of the gas tank ingesting water if this mod is done and then the truck fords, say, a stream? With the vent at the bottom of the can and the check valve removed it seems like there would be nothing to stop water from sloshing into the vant line. But, maybe I'm over thinking this. Sorry if this has been mentioned already.
I think before I did it, I read a few post up that someone did everything except drilling out the ball bearing. Might want to try that.I'm gonna have to do something along these lines soon. I'd love to get rid of the hiss when I open the gas cap, I just don't want to create an opening that will allow water into my fuel tank. I've had the 80 in water over the hood before and I'm sure that will happen again at some point.
From my understanding, while your engine is running the vent tube out the bottom of the canister is venting out with a positive pressure so I kinda doubt that you'd have water ingestion through that vent. Now if your engine stalled during a deep ford for a significant time or you parked in a lake.......it's likely to happen.Is there any risk of the gas tank ingesting water if this mod is done and then the truck fords, say, a stream? With the vent at the bottom of the can and the check valve removed it seems like there would be nothing to stop water from sloshing into the vant line. But, maybe I'm over thinking this. Sorry if this has been mentioned already.
One of the main things done in this mod is elimination of the check valve, the other is changing the charcoal. I'm pretty much convinced if you cut open your canister and don't drill out the check valve, you'll be tearing into that canister again wishing you'd done it the 1st time.I think before I did it, I read a few post up that someone did everything except drilling out the ball bearing. Might want to try that.
So I don't think drilling out the check valves is the "end-all" solution when the gasoline in your tank is hot/boiling. I drilled out both check values but still got pressure buildup and lots of fuel smell. My rig is running a little hot in engine temp, so that + ethanol + elevation change probably contributed to the gasoline boiling, which was more pressure than the engine could suck in and more pressure than the canister could purge to the outside, still leading to buildup. It also really stunk of fuel.
Check to make sure the line from the canister back to the tank is clear. In the summer you can still get fuel smell because one if when you modded you didnt replace the charcoal two because with the bottom of the canister being vented and the vapor are too much.
The VC120 is definitely vented, but it's vented out of the bottom portion of the canister housing itself - no vent hose like OEM.Honestly I would recommend against this mod, I get a terrible fuel smell when it is hot outside and regret drilling out the BBs. I'm planning to add some check valves back on the end of the vent hose to prevent the nasty smell. Many people here run the VC120 cannister which doesn't have any vent hose on the bottom, so positive pressure venting can't be that important?
