Easy check, what is the cast in head number?
With no rear drive shaft you will know if it’s a rear end problem or a front end problemWhat am I testing with this work? (Or what am I ruling out?)
How would I know?Random one, but could someone have put one of the heads for domed pistons on? I'd think you see that in the compression numbers, though.
Where is that on the head?Easy check, what is the cast in head number?
61030 so what does that mean?If my math is right, the open chamber heads are 61030 and 61031. Definitely a long shot, but it's any easy check to rule out (and it's happened before).
2F Head? - https://forum.ih8mud.com/threads/2f-head.108475/post-1369855
Ok whats theI haven't done the rear bearings, but spinning the rear wheels is easy. The front hubs do unlock and were cleaned and lubed when I did the knuckles.
Compression was posted in #98 130-150 across the board, not sure if that was we or dryI think those are open chambered 2F heads...I thought you mentioned prior that it had the earlier .5F?
I'm currently on mobile...but I want to say those heads go with the dome top pistons. Do you have a boroscope to peek down a sparkplug hole to see if you have domed or flat piston tips?
If it's got the wrong combo, compression ratio would be lower than it should be, which definitely wouldn't help power.
My 76 2F had the domed - reference:
With that head, I wonder if it's just still got the original factory 2F from 5/75...doesn't seem like you'd have the 68-70 F. It seemed like compression was ok, so it may have the right pistons...not sure of a way to check besides visual/boroscope.Background:
5/75 chassis with an estimated 68-70 F (PO said .5F but others have doubted that).
4 Speed transmission
32" tires
From pics earlier and in other threads, looks like he’s still got the oil fill tube in the block and no provision on the passenger side for oil filter, if I remember right. It very well could be the wrong head.With that head, I wonder if it's just still got the original factory 2F from 5/75...doesn't seem like you'd have the 68-70 F. It seemed like compression was ok, so it may have the right pistons...not sure of a way to check besides visual/boroscope.
One other thing that *could* be amiss if someone's been in it could be cam timing...if it's off a tooth, things would also get wheezy/wonky. I'm not sure if there's an easy way to test in-situ, though (vs checking gear alignment behind timing cover). Could possibly tell by watching the rocker arms vs TDC, but would need to know at what point a correct setup starts engaging...
Amazing, I have not really ruled it out. I cannot remove the muffler without cutting it off because of the way they welded it on to the mount. I could disconnect it at the manifold and wire it up temporarily, but without back pressure is it worth risking HOA complaints for the test?I once bought an old Farmall A tractor for 300 bucks a couple miles from my place. Was lacking power on the hills. On the last hill almost home, a rats nest complete with glowing embers erupted from the stack and showered me with hot filth, rags and nut shells. Good power after that. I forget now if you ruled out such an obstruction. If not, that's my vote.
DryOk whats the
