HZJ75 (45 Viewers)
wongtsenhin (how did you come up with that name?)
after bouncing back and forth on this i have decided to go with the large front diff. parts are easier to find. the center unit is much stronger. cheaper in the long run.
cheers
Wong Tsen Hin is my real name, not making out of something!:D This is a direct translation of my Chinese character.
Wong = Is the surname of our family
Tsen Hin = name of me
This is a good choice, cheaper route, easier source of part for swapping it to a 3.7 ratio. Well, I like to stick to high pinion as I have e/locker on the front diff. The only way to front big diff is by cable lock NO e/locker.
actually, that isn't true. the rear full size e/locker bolts right into the front large diff.
thanks for the break down of the user name ... makes total sense now.
Wayne, I know is bolt up. The motor of the e/locker is on the right side of the rear diff, If you bolt up to the front, the motor will be on the left side. Which means to say that you need a long spline shaft on the left side. This will be tougher job than finding the 3.7 high pinion gearset.:grinpimp: I hope you get the picture.
the long spline is no biggie at all.
the install is straight forward.
a lot less money than doing a 3.7 high pinion install ... in my books.
Recaro seat installation
After few months of quietness of my 75, today is time for my Recaro seat. Not finished yet.
Spacer for lifting the seat up and up.
Seat rail and stand
underneath of the seat
Adjuster level
Slider installed
2 spacer added (Trying on the height)
17 inches in width.
seat stand welded
Slightly better than my bench seat and 1/2" cushion.:D
NO!NO! bench seat can be seated with 2 persons whereas mine 1 left.:grinpimp:
One seat is preferred because of the centre console, bench seat block the way of the console.:bang:
Can someone enlightens me with this part no for diff lock motor? 12V or 24V??:confused:
Looking for a 12V motor.:D
i beleive the red tag is 24V but can be operated on 12V as well...
Really!
What is the color for 12V?:hhmm:
"can be operated on 12V as well" Sure???
Pretty sure there is a "brain" that controls the operation. Why is it located?
AFAIK, it is a direct bolt on.
but
the small diff uses a different attachment to the large diff
but
the motors might be the same size.
Another old girl of mine HJ45:D
Old and faithful H engine:steer:
Another HZJ75 by the side of my HJ45:frown:
75 sereis in the pic ...
i have started with worse. a diamond in the rough right there, i tell yah, a diamond in the rough.
