I tried the rope method but no go and was afraid I'd break something with the 14mm socket method so went with the bump start method which worked after a few trys. I did notice once the pulley was in my hands that the thin rim of rubber on the inner side of the pulley showed some very slight delamination from the steel, like a 1/3 mm crack between the two, so was it just from age or ?? and that's when it hit me; the crank pulley/harmonic balancer is made like a motor mount, rubber molded to two pieces of unconnected steel, correct? Too much stress between the two sides (like over 300 ft lbs going in opposite directions) and you can rip it apart.
