The desmog manual has a few errors in it that you noticed.
The charcoal canister IS AN EMISSIONS COMPONENT. The way Toyota set it up has the engine sucking in vapors from the charcoal canister when you’re driving.
If a person wanted to “desmog a 2F” the charcoal canister plumbing doesn’t have to be hooked up like Toyota did it.
This is a VCV.
The 2nd mysterious VCV was originally located clipped under the air cleaner cover on the passenger side. It regulated when the distributor can breathe to the air cleaner. It isn’t a smog component but a much desired distributor breathing component.
And This is a VTV.
VTVs are air flow restrictors. Vacuum air can flow freely in one direction but is restricted to a certain flow rate going the other way. Their purpose on the 2F is to slow the actuation of a vacuum diaphragm so it doesn’t slam open. Different colors designate different flow rate capability.
EGR ports refer to the pipe designations on the plastic EGR vacuum modulator.
You’ve GOT to have the Toyota emissions manual close at hand anytime you want to mess with the emissions components. See attached
