- Joined
- Jul 22, 2012
- Threads
- 639
- Messages
- 17,564
- Location
- Winter Park, Florida
- Website
- www.cruisermatts.com
On the Toyota LC joints? There are actually quite a few
We stock 5 common aftermarket Japanese joint part numbers that roughly 20 OEM numbers supercede into. The largest being the UJ36030 which is the common "4 speed" joint. It has 32mm caps, 94mm on the cross. The smallest of them (not including the steering and PTO u-joints we stock) is the UJ36011, commonly known as the "3 speed" joint. It has 28.5mm caps, 78.5mm caps.
As for the slip. The more spline you can have engaged, the better. It's well within reason that a factory slip-joint will work however long-spline ones are so easy to source that it might be worth considering just to take the guess work out of your setup.
Part# UJ35050 - $232.50 - Cruiser Outfitters
Thanks for posting that, I had no idea you offered a long-slip kit. I was about to order the Fail Gear kit!
