Here is my 74 FJ40. I bought it in September, drove it until early November when I decided to put a mild OME lift on it and start repairing the body including the POs fibreglass over layer. Shortly after putting the front OME springs in I realized it was not going to be tall enough for 35s. I came across some axles out of a 93 FJ80 and decided to swap them under my cruiser, including the front coils and radius arms.
Here is a list of what I've done or will be doing shortly:
-purchased missing bezel
-made a temporary rear sil, then replaced PO's plywood end gate with a drop down tail gate
-patch the PO's former roof vent
-replaced battery
-repaired rust on hard top rain gutter and b pillar
-fabbed a new front and rear bumper
-repaired rust in rear frame rails
-purchased used 8274 warn winch and rebuilt it
-fabbed rear spring hanger and shackle hanger for rear leafs
-moved the rear springs back 6 inches, which lowered the height a few inches to keep the SOA from making it too tall.
-cut all of the brackets off the FJ80 rear axle, mounted perches and installed.
-Next up is the front axle/suspension swap
Once the axle swap is complete I will be dealing with the PO's rattle can paint job and doing all of the body work, which may include a new 3/4 tub. I'd also like to swap a 1HD-T into it.
-replaced battery
