I removed mine while I was having body mounts re-built. I had to jack the body up a couple of inches. That crossmember causes lots of trouble. Let us know if it can be done without lifting the body.
You are underneath the truck trying to get the tank out? That calls for a WTF!
The tank is under the passenger seat INSIDE the cab. depending on what year you may need to remove the cover after you remove the seat and there are two straps holding the tank in. It is a 1 banana job at best.
