While on the road the other day I started to hear a loud clunk coming from my 80, it was very often, but it was quite noticeable. So I took a peak under the body when I got home. Everything seemed OK and I figured it might just be something coming lose again. In the summer I had I similar issue but it was because the bolt that holds the rear pan hard had some how worked its way lose and fallen out. I figured I would just go over all the nuts and bolts that night and see anything could be tightened up. Well, on the way to work the same day the clunk started to get worse, and I could feel it. On the drive home from work it got even worse, almost to the point were any bump on the road would initiate a clunk, even accelerating to fast. Now I was worried. As soon as I got home I looked underneath again and this is what I found...
Both rear upper control arms had separated. They're the Slee upper control arms, the lift is only a couple years old, and I'm only a weekend offroader... How does this happen?!
