- Year
- 1997
- Vehicle Model
- LX450
- Mileage
- 254000
- Color
- Black
Up for sale is my DAILY DRIVEN 80 series LX450 Landcruiser. Yes, I drive this truck 500 miles a week with no hiccups. Selling because I have found another vehicle I want.
This is absolutely one of the cleanest 80 series land cruisers out there.
Asking SOLD
Here is a list of details
- 254,000 miles and counting
- Front, Center, and Rear lockers fully operational
- Center diff lock switch
- OME Heavy front coils with Tough Dog shocks
- OME Medium Rear coils with OME shocks
- PHH, all little hoses replaced
- Wit's End Blue Fan Clutch Mod
- Seats and windows are fully functional
- 100 series fan mod
- Metaltech sliders
- No leaks
- New rear U Joints
- ARB Front Bumper
- Dark window tint
- All lights swapped with LED (not head lights or dash lights)
- Working factory key fob and alarm
- 285-75R 16 BFG All Terrains
- Ebay Snorkel
- Pioneer head unit with backup camera and hands free calling with bluetooth
- New Trailer Wiring
- FAT Maintenance history included in a binder full of receipts and notes from previous owner.
- No rust
The cons:
The valve stem seals are worn therefore causing the truck to burn oil (about a quart every 1000 miles). When the truck sits, oil leaks into the valves through the worn
seals. When you start it, oil burns off immediately. I have been daily driving it for the last 10,000 miles like this and have full confidence that it is fine and can wait to be cured. I have opinion's from local mechanics that agree. This is very common for these trucks. Besides this the front knuckles have just started to seep a little. These are the ONLY negatives about this truck.
Runs highway speeds at optimal temps of 185-190, eating no coolant.
Below is a list from a previous owner of work that been done during the extent of his ownership.
7/5/14 202,000 miles
Rebuilt front end, all new bearings and seals, new 100 series pads and disks, drained and filled T case and both diffs.
205k
New alternator brushes
New water pump and thermo
New oil pump seal and front crankshaft seal
New Koyo radiator and hoses
New EGR hoses
New distributor o ring and gasket
PHH delete and new hose
Oil changed
209k
New starter
5-1-15 212k miles
Oil changed
850 + 30 mm front new shocks
860 rears
Caster correction plates
Sway bar drop block
Rotated tires
1-8-16 222,798 miles
Rotated tires
Oil change
2/6/16 223,267
New cap and wire set
Pcv valve, grommet, hoses
Ngk plugs
1/2/17 231,180
EGR valve
VSV modulator
Throttle body gasket
Vacuum hoses
Upper intake gaskets
Degreased with simple green
2/4/17 231,700
All radiator hoses
AC tensioner pulley
Tstat and gasket
Full cooling system
Oil pump cover seal (again)
Flush and refill coolant
Crank shaft seal (again)
New lower pressure hoses
New belts
2/30/17 236,500
Leak down and compression test
100 series condenser fan installed
Oil change
6/18/17
Rear coolant hoses
Replace PHH
Replaced coolant
8/1/17 244,000
front rotors and pads
You get this documented note book as well as receipts from the owner after this one documenting further work. The most recent work was new rear driveshaft U-Joints,
new rear passenger axle seal, front axle bearings re packed and sealed, and brake job.
Once again I am asking SOLD and the truck is located in Houston, Texas. It is my daily driver and can meet anywhere in the houston area.
Below are some photos as well as a dropbox link to more and videos.
Thanks for reading!
Photos and Videos - Click link
Asking SOLD
- Metaltech sliders
- No leaks
- New rear U Joints
- ARB Front Bumper
- Dark window tint
- Ebay Snorkel
- No rust
The cons:
205k
New EGR hoses
Oil changed
209k
New starter
5-1-15 212k miles
Oil changed
860 rears
Sway bar drop block
Rotated tires
Rotated tires
Oil change
2/6/16 223,267
Ngk plugs
1/2/17 231,180
EGR valve
VSV modulator
Vacuum hoses
2/4/17 231,700
All radiator hoses
AC tensioner pulley
Tstat and gasket
Full cooling system
New belts
2/30/17 236,500
Oil change
6/18/17
Rear coolant hoses
Replace PHH
Replaced coolant
8/1/17 244,000
Thanks for reading!
