LC’ers
I am having difficulty getting the Horn to blow from the button. 1972 LC soft top manufactured 10/71.
Work done:
· Correct Period steering wheel installed
· New Horn seat with button contact installed. Ran a new wire through the steering column and rubber, soldered wire to the Contact Ring (See attached). Other end attached to the Relay (where the Green / Red wire would have attach per the diagram).
· Installed new horn relay under the bonnet and grounded the relay to the fender.
· Followed the attached wiring diagram see #7 (Relay) and #29 (Horn Button) from this site: Wiring Diagrams | Vintage Cruiser Co.
What is happening is:
1. The horns both work, jumped them directly from the battery through the Green and White wire
2. Push the horn button and see blue electric spark in the steering wheel (which means there is connectivity). But the horns do not blow.
3. I swapped the Yellow / White wire on the relay with the new wire ran from the steering wheel and re-connected the battery, the horn blows constantly. (Confirms that the wiring to the horns works).
Something tells me the wire that runs through the steering column to the horn should run to something other than the relay. (Maybe directly to the horn fuse, I tried this, and re-connected the Green / Red to the relay, and had no luck.). Hoping my fellow LC’ers can help.
Thanks all,
Boaf
Work done:
Thanks all,
Boaf
