- Thread starter
- #21
FJ40 fuel & temp gauges stopped working.
Recently while driving around town my fuel & temp gauges would randomly quit working...both at the same time. They came back to life a couple times then just quit all together. With it raining today it's a good time to investigate.
I removed the batt cable (don't do this job with power on the harness, you can short and damage the cluster) then pulled the gauge cluster.
I checked for voltage on pin #3 on the cannon plug (ignition power) and it has good voltage. Scratch that one off the list.
49 years of use has tarnished the copper electrical connections on the cuircut board. I removed all of the electrical connections one by one as well as the ground connections and cleaned the contacts with a burnishing tool.
Re-installed the cluster back in the dash and....working again! Topped off the fuel tank and watched the gauge work its way right up to full. Temp gauge is up and running as well. Perfect!
Hodakaguy
Hodakaguy
