wesintl said:I don't think temp would make a difference but it would be cool to do that roof white.. I think the high roof would esp stand out
I'm sure we can photochop that..
white...
tlcruiserman said:I think we found something worse than a truck with a lot of visual problems like engine, rust, etc. This truck was very sound in the body department and most of the drive train, very very little rust. However it must have been very neglected or used beyond normal limits because everything in this truck did not work, and needed fixing. Even down to the rear windshield washers had to be fixed. I think spending most of its life in Honduras it paid its dues from lack of correct parts to poor work done on the truck. I could talk about all the stupid stuff that did not work for hours. So when I tell you that a lot of work went into this truck it is more than the average restoration. Jan & Gina spent countless hours on just stupid silly stuff on this truck, I think there is maybe a few 12mm bolts that were not replaced, but I am just guessing that may be the case.
Great Work Jan and Gina![]()
Jan-78FJ40 said:Here is an update:
We got the truck drivable this weekend. We fixed the power door locks (the switch wad irty and the wiring the usual hack job). It got a new slave cylinder, and the brakes needed to be re-bled. Then we replaced the rear windshield washer hose (what an enormous pain!), and put the hood back on.
It drove beautifully, with lots of power, but developed an annnoying problem on the way home from Michael's garage: The fuel control relay would double click, and then the truck lost power for a fraction of a second. This made it hard to drive, especially uphill.
We had a smilar problem before, right after we dropped the engine in, and it was ground related. Therefore I cleaned up the ground from the new clutch slave to the frame, and also installed a new ground from the edic housing to the frame. this fixed the problem.
The truck is clearly overfueling, since it puts out a huge amount of black smoke under load at higher RPMs. Anyone a picture of the adjustment system?
In the mornings when it is cold (0 Celsius, which we call cold here in San Diego) the power steering fluid bubbles out of the reservoir. This is apparently due to wrong fluid, I put in regular power steering fluid instead of Dextron 2 ATF-we'll fix that on the weekend.
It needs a stereo, but has no brackets. Does anyone have the info how the original radio was anchored under the dash?
I'll update as we go along, and then of course about the turbo install.
Thanks
Jan
zander said:I am curious about your power locks. Are those factory? I would love to get some 24v power lock units for my rig but never found the right source.
Jan-78FJ40 said:Thank you for the information!
The power locks are factory, and the truck does not have power windows. The setup is factory and similar to an FJ62, with a solenoid in every door, and 2 relays in the trunk wall. They are activated by a single switch on the drivers door.
The truck is 12V though, and from Honduras, and has a number of options that were not available in the USA.
Jan
crushers said:there are 2 different brackets for the HJ61 radio support. you can order the ones from toyota that work excellent with the "modern" radios. get the ones for the BJ60 CND model or the larger ones for the HJ61...
the radio mounts with no problem at all.
cheers
