Does anyone have advice for the actual install? I have a 92 w/o latch The graco install manual and FJ80 manual are completely diff.
Thanks,
xander
Are we talking an infant seat with base still or a toddler seat or a booster seat?
And when you say the Graco and FJ80 manuals are completely different what do you mean? They differ in how they tell you to install the seat? In that case I'd go with Graco states as that information would be 15+ years newer and up-to-date.
As for the install here are my opinions:
Infant seat with base: If possible put the base and seat in the center seat position that has just the lap belt. This puts the baby in the center and most protect position. Put the lap belt through, pull as hard as you can to compress the seat and base together.
If you have to put the seat on an outer seat position put it on the DS seat position (read somewhere it is slightly safer than PS because the driver tends to see stuff that is about to hit their door better than a PS impact). If your belts don't lock then you should use one of those "buckle" deals to hold the lap belt and shoulder belt together - Some use the buckle regardless. Again, sinch that bugger as tight as possible. I kneel on the seat with all my weight while pulling on the belt and when down that sucker doesn't move
Toddler car seat: Basically the same as above...Middle position is best, then driver's side as second. After that, I put the youngest on the DS and oldest on the PS. Shouldn't need the "buckle" as long as your belts lock.
As for the "latch". Are you referring to the strap from the top of the seat that should go to a hook on the floor or similar? I latched mine to a rear cargo tie down. Not a perfect solution but better than nothing. You could also try to hook it to the 3rd row seat floor bracket.
Booster seat: This one is pretty straight forward. Center position doesn't work as there is no shoulder belt so DS position first then PS position second. Again I put the youngest on the DS while some just say to pick your favorite and put them on the DS
Hope this wasn't WAY more than what you were asking. I've seen may car seats that parents just kind of half ass buckle in not worrying about it being loose so figured I'd be specific as to what worked for me
