Higher amp output 24v alternator for 1HZ? (4 Viewers)
woytovich
Science...
Metro NY
I'm looking to bump up my alternator output. I'd like to get a little more oomph for if/when I run a 24v inverter that can draw up to 120a:
Anything that'll bolt right up? (I know I will want to upgrade some wiring to handle the increased current.)
I installed this 60 amp 24V alternator:
Not a high output alt by any means, but much better than the anemic 35 amp that is usually paired with a 1Hz. For a 24v high output I would look to marine applications and alternators such as Balmar. Most European yachts have 24v systems.
With out knowing anything about the overall system you plan to install, using your 24v starting system is generally a bad idea for supplying "house" power. A 120 amp draw would be very hard on a battery bank that isn't set up for it. One of the smartest systems I've seen is what @umpqua did with his 24/12 volt system. He has the stand alone, 24v stock setup for starting and running the car, and a 12v high output alternator for powering his house batteries, and everything not related to "running" the truck.
If you use that alternator I posted, or any larger alternator you will need to change the alternator bracket. Let me know if you need the PN for the larger throw bracket, it's buried some where in my notes and here on Mud
I don’t recall the model number but I installed a high output Terrain Tamer alternator on my 79 Series.
Perhaps that’s an option for you.
What kind of load do you plan to put on that inverter? That's 2400 watts - you could boil gallons of water, dry your hair, and microwave a turkey all at the same time without drawing from the battery.
All joking aside, I have a 100a 12v alternator which is pretty big in the 12v world. A 50a alternator @ 24v would be the equivalent.
Depending on what you want to run off the inverter that may be more than sufficient.
I am not sure but I THINK my 1HZ alternator is something like 35a (at 24v). I got an overkill/ higher watt inverter to have cushion over my expected use, which at the moment is just a 1000w electric kettle, and for the "maybe" need in the future (plus it was on sale)
(It was on sale for less than this when I bought it)
OK, so this is all being powered off your vehicle 24v system.
If it were me, I wouldn't try too hard to find an alternator that could power the inverter at full load. It will be hard to find and will be way overkill.
Instead I would consider the load, the duty cycle, and the capacity of your battery.
For example, if you were to run the inverter at full tilt, making hot water for a dozen cups of tea, the blender for margaritas and the microwave for ramen all while charging a dead laptop as you dry your hair, you might hit 2500 watts but only for a few minutes at a time.
Your batteries (if sufficiently cabled) could make up for any deficit in what the alternator could produce.
Then when the loads ramp down, the alternator can recharge the batteries.
So if you ran a 2500w load for 10 minutes, and a 50a alternator is producing 1200w, then your battery has to provide the other 1300w for 10 minutes, or 1/6 of an hour.
((2500w-1200w)/24v)*(1/6 hour) = 9aH
It wouldn't take your 50a alternator long to replace that. Even a 35a alternator wouldn't take too long if all it is doing is running the engine. Turn on your heater and bright headlights and it would take a little bit longer.
Just don't run the winch at the same time!
The example is simplified and doesn't consider efficiency and cable losses and such, but it gives a sense of how to look at the whole system.
So reviving this thread in hopes that 24v 100a (and up) alternator options have materialized... anyone have any additional input on this?
Mark,
For your consideration, checking on alternators in Coaster buses equipped with 1HZ (or similar) might yield what you are seeking.
FYI The heart of my BJ70 is now a 24V 15B-FT out of a Coaster bus. Earlier this week, I took the alternator off and took it to a rebuild shop. They put it through its paces and it checked out fine. The tech also ran max performance tests because I asked what the capacity was. The 15B-FT alternator maxed out the test equipment/machine at 120 amps. (I failed to ask what the rpm of the test was) The technician projected that the alternator max capacity was probably in the 150-180 amp range.
Based on this experience, my thought is a similar alternator from a Coaster bus may have the performance capability that you are seeking plus additional margin for confidence in a long life for you.
Good luck
Mark,
Good luck
Sweet.... thanks Larry.
Relevant info here:
