High-Mileage 200 Baseline & Build (3 Viewers)
Tuscaloosa, Al
The story begins with a need for a bit more backseat width so that the mother of my children could fit more comfortably between two car seats. Our GX460 (pictured) was beloved and took us to many a national park on the East Coast, but the middle seat left much to be desired in terms of comfort and width. As this is the vehicle my wife drives daily, the "build" for it was neither dramatic nor expensive, as I tend to scour marketplace and forums for gear that may not be an exact vehicular fit, but with my fabrication/engineering prowess, I make work for our needs.
Well, as luck would have it, I drove past a 200 a day after my youngest child was born and figured I'd stop in and see what they wanted for it. I have had LCs in the past and had been looking for a 200 for the last two to three years, biding my time until it made financial sense to do so. The GX served its purpose fine and was a reliable rig for our moderate adventures and daily driving, but I figured, why not ask?
An hour later, I was driving home in a 2013 200 series with 315,500 miles on it for a whopping $16,500. It is a single-owner vehicle with a fair history and extensive highway miles, due to the nature of the work the previous owner was involved in. Many hours on the interstate between Alabama and Texas. It was purchased at the local Toyota dealership and maintained there for its entire life up to now. I have all of the original documentation from the initial purchase, including the window sticker, which I greatly appreciate.
It had a minor leak from the coolant valley plate seal when I inspected it before purchase, so I have had to get that replaced by the dealer. I swapped in a new filter, cabin filter, and a fresh PCV valve for good measure and cheap insurance. It needs tires, brakes, and a suspension refresh, but overall, it's in remarkably good shape for its age/mileage.
I'll continue to update this thread with more baselining, which I am sure I will have questions about, and build plans/progress.
I also went from the GX460 to the LX570/LC200 platform. Other than the GX460 being a bit easier to fit through narrow trails, everything else is better in the LC200 platform. Welcome!
I put together an order of operations baseline checklist when I went through things. I'll link to it below. I'm also just up the road from you in Central TN, so please reach out if you ever head this way & want to talk shop!
10-4! Much appreciated! I will use your list and add to mine with it!
I surely will reach out next time I am up that way! Just gave you a follow on Instagram too.
Why is the exhaust bright silver? Looks super clean!
I cleaned/polished it really, really well when I got it home. It was really dirty, so I figured I'd give the axle-back a fresh lease on life. Need to wax it, but waiting till some cooler temps.
Awesome. FYI it’s black from the factory if you want to put some high temp stove paint on it.
Thank you, sir! I'll do just that! I was unaware that the tips were black from the factory and just wired off everything!
Replace the radiator if you have the old style, I patched my old one and it helped with jb weld til I bought a new one.
I went to 15w50 Mobil one for the last 30,000 miles with oem filter.
The truck likes to eat brakes. Big power and weight do that. I use the Advics from rock auto.
I’ve just recently replaced my oil filter housing with the metal aftermarket one. It makes it way easier to get the filter socket on and off.
Thanks! I am luckily familiar with brakes and big vehicles with my Super Duty!
How might I find out if I have the old-style radiator?
Got around to tackling some more simple maintenance items this weekend. First was the PCV valve. The absolute hardest part was the foam surrounding the valve. I could not, for the life of me, get it out so I just squished it to the side while I replaced the valve. The original was still moving and functional, I think, but it was quite crusty.
After that, the headlight bulbs were flickering, so I decided to order and replace them with the recommended Toshiba D4S bulbs. The install was not too bad once I figured out how it all came apart and went back together. It made a significant difference in both light quality and output.
The only surprise I encountered was when I removed the windshield washer fluid fill neck to create more space for the driver's side light. Note to self, don't remove the neck when the fluid is completely full. I was able to stop the pour by stuffing a paper towel into a rubber glove and jamming it into the canister. On the bright side, my garage got a good mopping after this.
I also snapped my first parking lot picture.
