I plan on doing the exact same, funny enough with an identical USB charger on the back of my Tuffy box when it's time to put it under the knife. What are you using the switches to control? I think my grandmother's early 80s Oldsmobile had identical switches for the windowsTest fitting switches in Mary's console prior to media blast and paint.
I like the box in the background of the first two pics.Tex is a roller!! Out in the sun for the first time and now the body is going back on.
Thread is due for some Pi photos, no?Our new shop dog Pi, big shoes to fill, RIP Max.
Pi is a Catahoula Hound Leopard variety![]()
What advantages are there to running one over the other as far as NV4500 versus T4050? Is it just a noise factor and the NV4500's reliability of the rebuild?Sugar is getting a 5 speed transplant. Out with the NV4500 in with the Tremec 4050
Axis industries adapter. No provision for a T-case shifter so made up a mount using the plate and pin provided with the NV4500 adapter.
No glitches so far in the installation. Bolts right up to the same bell housing and uses same clutch and pressure plate set up as the NV4500. It was almost too easy, still waiting for the other shoe to dropDrive shafts will need to be made to the correct length as this set up is a bit longer. Cross member needed to be changed as well.
Seems to be a great alternative to finding a uses NV4500, rebuilding it and hoping it does not make a lot of noise in 5th gear.
Tremec 4050 and Axis Industries adapter. 6.0L Vortec motor. I love this particular truck, my favorite so far, it should be a bit quieter now
