HFS-Around the shop
Think an LS swap will hurt the value of your 60 or 80? This truck was built in 2017
S'cuse me I gotta go change my pants.
Back to Leon. All jambs, inner doors, gate and hatch, inside doors all stripped to metal, prepped and being sprayed with epoxy primer
Lots of exposed metal inside a 60. More when you dump the plastic in the back and the wrap over door cards.
3 coats epoxy primer on everything except inside the body
Got all the inside metal all sanded out and primed with epoxy primer. All metal is now primed out with 3 coats of epoxy primer.
It never ceases to amaze me how much total work is involved in prepping out a vehicle for paint.
For those of you who are curious, the area of an FJ60 roof is 1.7 acres (when sanding the damn thing)
Every square inch gets sanded out lightly at 320 and then gets shot with 3 coats of build primer. You guessed it, it then gets sanded out AGAIN and AGAIN!!
Fast forward................ got a couple trucks wrapped up and out the door and got back to painting Leon. I had to wait over a week for another day with humidity low enough to spray clear
Nardo Gray
