workingdog
GOLD Star
So, this poor '66 has been through two V8 conversions. It's interesting to look back at the '64 wiring diagram that @Coolerman was kind enough to send me. My rig originally had a generator, a voltage regulator and a real ammeter. Now I have an alternator with built in regulator and a voltmeter. In addition, all of the engine and most of the ignition wiring has been replaced as part of the conversions.
Over the years, the wiring behind the dash has become a disaster and rehabilitating my cowl top vent has motivated me to finally attack it. Now I have a bunch of wires I'm not sure what I need and what I can abandon. I have wiring diagrams from '64 and '71. The '71 has color codes but is very different from my rig, the '64 is closer to rig, but has no color codes and no indicated what what wires were in what part of the harness where.
So, here's what I got.
This is the sub-harness coming off the main harness almost dead center running along the dash under the cowl top vent. Any help identifying these would be appreciated. They are mostly wires that had been attached to the down stream side of the original fuse block on the hump above the gas pedal.
In addition, I'm not sure what to do with the large wires that used to go to the ammeter. I hooked them together just for continuity, but can I abandon them?
I know that originally, they ran to the alternator, but the alternator is now hooked directly to the power stud next to the battery.
And then, there are these two connectors, in the same general location.
I'm assuming I'll just zip tie these up to the main wiring harness trunk.
I now have a painless fuse block that I've run a new large +12 wire to. One of the things I'm doing to clean things up and make things more accessible is moving it from the upper left corner of the firewall to the center hump where the heater used to be.
Under the hood, I have a bussman resetable breaker acting as a fusible link. Right now, I have a blue white wire from the old harness still connected to the stud. But I think I can abandon that too.
