Help with removal of a split case
Discussion in '40- & 55-Series Tech' started by SMG, Sep 18, 2017.
  1. SMG
    SMG SILVER Star
    953
    716
    Oct 21, 2014
    No where fast.....
    So I searched for this subject and I'm not having any luck.
    I have a 83 4Speed transmission with an attached split case that I need to remove.
    I do not need the 4Speed but would like to save the split case for a later install onto my 76 40.
    Does someone have a link or write-up on how to do this?
    I want to make sure I have all the proper tooling before I begin.
    Also, this trans/transfer combo is not installed and is currently on a cart in my garage.
    Any help would be greatly appreciated.
    Thanks
  2. cruiserpilot
    cruiserpilot
    5,236
    1,536
    May 15, 2005
    Ladysmith
    I hope you have a couple of hours to spend now. No special tools needed to take it apart, which you will need to
    do in order remove the front half of the case from the trans. You will need to order new gaskets and stake nuts
    at the very least. Take lots of pics of the 3 main gear assemblies as you take it apart. There are little shims that
    need to go back exactly where you took them out. I think there is a video that Georg added to the end of the thread.
    This would be a good time to decide how many miles on the case and whether a bearing rebuild is in order. It is
    coming apart to that degree when you split it and remove all the parts. Get a large plastic tub with a lid, and keep
    the parts in order.
    Honestly, if you can keep the thing assembled until you need it that would be the best advice. As usual taking it apart is
    an hour, but missing parts/where does that go? are forever.
    some h55f and split case tech
    thebigredrocker and SMG like this.
  3. 3_puppies
    3_puppies SILVER Star
    9,530
    666
    Dec 2, 2002
    Helena MT
    easy to separate and store in a tote
    the split case will not work on a 76 4 speed
  4. SMG
    SMG SILVER Star
    953
    716
    Oct 21, 2014
    No where fast.....
    True, I plan on using it with my NV4500 via Advanced Adapter.
    Great Video! Should help tremendously.
  5. SMG
    SMG SILVER Star
    953
    716
    Oct 21, 2014
    No where fast.....
    Dumb question, How do I remove the front output shaft/gear/bearing from the front side of the case? I’m pretty sure it needs to be pressed out?
    Anyone do this recently?
    Thanks
  6. roma042987
    roma042987
    4,228
    Media:
    3
    Albums:
    1
    2,092
    Mar 30, 2011
    huntsville al
    remove front seal and oil slinger then knock the shaft out. Then remove the retaining ring and knock out the bearing from the inside out.
    SMG likes this.
  7. SMG
    SMG SILVER Star
    953
    716
    Oct 21, 2014
    No where fast.....
    Thanks, I got the shaft and bearing out. I was really surprised how tight the shaft was into the bearing. At this point, I cleaned up the hafts and bagged all the parts. From what I can tell, all the gears and shafts look good. Now I just need to decide if I want to order a rebuild kit and swap out my single case.
    Currently my single case is in really good shape so I may hold off for now or just put it up for sale.
    Thanks for your help.
    roma042987 likes this.
  8. Living in the Past
    Living in the Past SILVER Star
    13,743
    1,533
    Apr 21, 2005
    Believe there is at least one person looking for a split trans case from a 83+ right now. Those have the provision for the fifth gear oiler. Unless you plan on a Orion case would buy a AA adapter for a split case and run this one.
    SMG likes this.
  9. FJ60Seth
    FJ60Seth SILVER Star
    1,554
    289
    Nov 15, 2010
    Altadena CA
    There’s a lot of split case info in the 60 section.
