Help. Calling all RHD 75 series
Anchorage, AK
So, doing the sound proofing of the floor I accidentally covered up the bolt hole for the right side seat belt bolt. No easy way to locate it without removing the fuel tank, which I don’t want to do, at least not yet🤣. Can someone with a RHD 75 make a drawing with dimensions of where this hole is? Appreciate it. In the picture where the silver pen is pointing at is the seat belt bolt hole for the left seat (bench seat) on a RHD 75 series.
Ouch!
If I can remember this.
Will look for bench seat hole though mine is currently a two bucket setup.
I need the location of the drivers floor seatbelt anchor point. I have the one for the bench seat
I assume that anchor point would be different for a 75 Series vs a 79 Series cab?
It was there but I accidentally covered it with the sound proofing šŸ™„
I have the 3 passenger front seats (split bench) so my two seats are only 2" or so apart. You must have bucket seats in front?
You could fish with a needle....
Don't say I don't love hj75's, appeciate Taco or Mud!
95mm to the left 120mm to the back center of left back bolt hole of handbrake. Sorted. (had some more pressing issues for a tad)
In my BJ73 all these holes penetrate through the floor panel. When stuff is bolted in, you can see the bolts from below.
You may be able to find the holes from under the truck and stick a needle through?
Do you think my LHD 73 would be the same?
