- Thread starter
- #61
Any thoughts are appreciated. No stone left unturned.
I just got UPS notification that master #4 is at my door.
Not sure I understand what the solution was. was it a power bleed of the system?
For the last week, I have been having a soft pedal for the first 2 compressions of the brake pedal and the 3rd is usually rock hard. With the power of the web and asking a few people, I have come to the conclusion that it could be either the master cylinder or the booster or both.
So today in preparation for the worst I removed the ABS and LSPV. As a reference I used: JeepinPete's ABS/LSPV delete great write up by the way @JeepinPete I only took one picture of the whole process and that was of when I had the ABS pump out.
My routing of the brake lines is not as clean as JeepinPete's neither is my engine bay. But this should give you a good idea of how much more room you should have after deleting the ABS.
The only issue I had with the LSPV was unbolting it from the frame. But I removed the nuts that hold the LSPV to the bracket and got it off that way. There are 4 bolts that hold the bracket on are accessible, 2 are easy to get to the others are a pain in the ass. They are up between the frame and gas tank.
Tomorrow I will bring some brake fluid home and refilling the reservoir and bleeding them with the help of the wife on Tuesday.
Honestly, I don't know either. The brakes felt the same after power bleeding with the final master/booster combo. It was not until my wife came out and we did power bleeding with old fashioned pump bleeding that it suddenly became better.
After much reflection..... I think it was either my wife's magic touch... or the power bleeder and regular bleeding pumping the brakes that was the final answer.
I talked to @kc_chevota yesterday, and that is exactly how he bleeds his brakes now, so that might be the answer.
Sorry for this question but I'd like a little more clarification. I have a Motive power bleeder as well and from what I understand, here's the trick: pressurize the system with the power bleeder, then use a second person to pump the brake pedal three times and hold. Then open up the caliper nipple to purge any air left the system. I assume you followed the FSM's sequence of brake bleeding procedure.
Is all this what you did?
Exactly. I pressurized to about 17lbs on the bleeder and started in rear pass side, rear driver, front pass, front driver. I typically call it a bleeder valve on the caliper, but I like how you snuck in the word "nipple".![]()
I have been replacing my master with the t100, larger bore. If you did the abs delete, we have had to do this to all those rigs for some reason.
ADVICS BMT139 sometimes hard to find, but solved our issues.
Seiken 650-71450 is the booster that might be OEM -- might not. the arguement goes on...... but it seems to work great and look identical.
What model Motive bleeder you have? Hoping to save some headaches getting the correct one the first time.Exactly. I pressurized to about 17lbs on the bleeder and started in rear pass side, rear driver, front pass, front driver. I typically call it a bleeder valve on the caliper, but I like how you snuck in the word "nipple".![]()
