Hi,
Almost $3700 on master cylinder and replacement of pump of 1999 LX 470!!! Details further below (mechanic emailed me the specifics).
Here is the short of it. Mechanic says, "Master Cylinder is leaking onto electronic components and pump. I am having trouble buying the Master Cylinder and Pump and other parts separately. So, from what I can see on my computer, I need to buy them OEM all at the same time." (I am paraphrasing here).
I don't blame the mechanic. It can be difficult to see/tell what you are getting.
SO HERE IS MY QUESTION: Does anyone know where I can get the required part for much less money???
Your help is sooo much appreciated.
DETAILS EMAILED FROM MECHANIC:
1999 Lexus LX 470 4.7 L 4663 CC V8 DOHC 32 Valve
$258.75 MASTER CYLINDER Remove & Replace M
$103.50 MISC. LABOR CHARGES
CUSTOMER BELIEVES IT NEEDS A NEW MASTER CYLINDER
WHEN CUSTOMER BOUGHT VEHICLE, HE WAS MADE AWARE OF BRAKE LEAK, ALARM SYSTEM WILL BEEP AND BRAKE LIGHT COMES ON
CUSTOMER WOULD LIKE TO KNOW IF IT IS POSSIBLE TO JUST REPAIR THE PART INSTEAD OF HAVING TO ORDER A NEW ONE.
INSPECTION FOUND THE FOLLOWING
FOLLOWING DTC PRESENT IN MODUAL
C1252 HYDRO BOOST PUMP MOTOR FAULT
C1256 ACCUMULATOR PRESSURE LOW
PEFROMED COMPLEATE CIRCUIT TEST ON UNIT BASED ON PRESSURE READING ASSEMBLY HAS FAILED, MASTER CYLINDER LEAKS AND IS LEAKING ONTO THE BRAKE BOOSTER PUMP, PUMP IS FAILING.
CUSTOMER REQUESTED REPLACMENT OF MASTER CYLINDER, THIS WILL NOT ADDRESS ISSUES WITH THE PUMP AND MODULE, AND LOW PRESSURE
SYSTEM WILL REQUIRE COMPLEATE REPLACMENT TO ENSURE SAFE OPPERATION OF VEHICAL
QUESTIONS CALL ALAN 509-374-5783
$2,999.90 ABS MODULATER KIT
INCLUDES
FULL ASSEMBALLY
MASTER CYLINDER
RESEVOIR
BOOSTER WITH ACCUMULATOR
RELATED HARDWARE
$14.00 GASKET
Note: M - Labor Database, Copyright, Mitchell International, All Rights Reserved
$362.25 Labor
$3,013.90 Parts
$0.00 Sublet
$15.53 Shop Supplies / EPA
$0.00 Charges
$291.68 Sales Tax (Tax @ $3,391.68 * 8.6000%)
$3,683.36 Repair Total
INCLUDES
FULL ASSEMBALLY
MASTER CYLINDER
RESEVOIR
RELATED HARDWARE
$14.00 GASKET
$362.25 Labor
$3,013.90 Parts
$0.00 Sublet
$0.00 Charges
