I have not posted in a while and typically search a bit before I post. I was unable to locate a post that satisfied my question as it is obscure and difficult to search.
Today was the first time in a while that I had driven my 60 to work. It used to be a daily driver, but I recently bought a beater car to drive to and from work so my 60 could stay in the garage and out of the elements. I just changed the oil and all the bolts and filter were on tight.
Went into work with not noise or anything. Came out for lunch and noticed a larger than usual pool of oil under the truck. The more I looked at the undercarriage the more spatter I found. Most of the moisture was concentrated on the passenger side of the engine below the plugs. Real wet, not typical cause I keep it clean. Checked the dipstick and it was bone dry. Filled it up again (no direct drain to the ground). Started it up. No knocks and sounded normal. Walked around to the passenger side where all the moisture was and oil was spewing from what looked like a bolt hole above the #5 plug on the head (quickly shut it off).
There appears to be an outlet and I am not sure whether a bolt wiggled its way to freedom or whether it blew off something. I was wondering if someone can provide some insight or peak under their hood and let me know if there is a standard plug or something that was blown off. It looks like a bolt hole above #5 and it is angled towards the firewall.
You guys have always helped in the past and any help would be greatly appreciated.
Thanks
Brad - Formally of Socal now of Eastern Va
Thanks
