#1 plug is same oily plug that I cleaned off to include in line up.If these are the 8 plugs (1st pic) you just pulled out. I wouldn't expect the engine to run at normal operating temp. Not good, if these plugs are representative of how engine tuned/PM'd. I would expect to see P03** DTC (codes), in this 4.7L.
It's the strangest collection of spark plugs and most confusing info/pic, I've seen. Your showing number #1 in the group that is different and dry, than the #1 by itself very oily. Which is from oil in spark plug tube, not combustion. #4 in group, I see TT/Denso. Which is not a real Denso TT plug. Likely a boot leg.
Bk2 plugs looks cleaner, possibly mild steam clean, than BK1. But with unknown age and mixed matched plugs. I'd not make that call.
Oil did show full but I just changed it two days ago. However It has been using/burning/ seeping oil slightly. I think the smoke smelled more like oil than coolant but looked too white to me to be all oil. But what do I know.Did you check the oil level on the dipstick as well to make sure it wasn't low? Did the smoke smell sweet?
Lexus or Toyota coolant are the same. They're either LL (red) 98-03 or SLL (pink) 04-07.
Did they give you pictures of leak?
Head gasket leak can be seen, unless between coolant passages and oil drain port. Which oil analysts can reveal.
Head gasket leaks, are typically due to overheating warping head.
Thanks for taking a look 2001LC. To confirm: you are saying that you would want to 'see pressure test blow it out where pink arrow is pointing at head gasket'? This would better pinpoint the issue on mine? ThanksThat is coolant (pinkish crusty, outlined in yellow) leak for sure.
If it is the head gasket. 99.8% chance, engine was overheated. I find water hoses swollen, 8 out of 10 times, when that happens.
But point of leak, is not shown. I'd like to see pressure test blow it out where pink arrow is pointing at head gasket. The blue arrow points to rear water bypass joint on top of engine head. It also could be a leak, and come down block. Also notice the block drain in my picture. It too could be a leak. Just forward of oick crusty is block water hose going to oil cooler.
