Head gasket leaking…looking at my options. (2 Viewers)
how are 7 4 and 1 not real? I'd bet they are the oldest, real, and from the same box.
If these are the 8 plugs (1st pic) you just pulled out. I wouldn't expect the engine to run at normal operating temp. Not good, if these plugs are representative of how engine tuned/PM'd. I would expect to see P03** DTC (codes), in this 4.7L.
It's the strangest collection of spark plugs and most confusing info/pic, I've seen. Your showing number #1 in the group that is different and dry, than the #1 by itself very oily. Which is from oil in spark plug tube, not combustion. #4 in group, I see TT/Denso. Which is not a real Denso TT plug. Likely a boot leg.
Bk2 plugs looks cleaner, possibly mild steam clean, than BK1. But with unknown age and mixed matched plugs. I'd not make that call.
#1 plug is same oily plug that I cleaned off to include in line up.
I have had misfire codes in past and replaced with newer plugs when necessary. As long as running good I haven’t just replaced all at once as you can tell. I did just put in all 2R011 Iridium’s however.
If the oil was from within the cylinder it could be bad rings causing oil to get into the combustion chamber. That would coat the plug and cause the misfire. The leak down test would confirm if it was the rings as you would hear air hissing out of the PCV or oil dipstick tube.
Right now there are no misfires nor right before I pulled out oily plug. Runs really well.
Just FYI…Don’t mean to bother. After driving yesterday, this morning I took out plug #1 to find no oil at all on plug. Cranked it and got exhaust below. Just drove 75 mph with max temp at 204 with 170* tstat.
Did you check the oil level on the dipstick as well to make sure it wasn't low? Did the smoke smell sweet?
Oil did show full but I just changed it two days ago. However It has been using/burning/ seeping oil slightly. I think the smoke smelled more like oil than coolant but looked too white to me to be all oil. But what do I know.
Could be coolant, could be oil. Likely both in your case. Loss of coolant & oil, with no apparent leaks to account for amount of loss. Would be first indicator (s).
Oil smoke tend to have a blue tint. But depending on lighting and ones eye, difficult to distinguished. To me, oil smoke looks white.
Coolant=head gasket most common. Crack in block or head much less common.
Oil= Valve steam seals or oil rings, excessive crank case pressure (PCV system and or compression rings)
Just this last week I noticed the smell of coolant after I got out of my 1999 LX470 when driving it. This LX has ~220k miles on it and the previous owner changed the coolant to Lexus coolant back at ~190k miles in year 2019. I have not noticed any performance issues, rough idling, smoke, ect. aside from the smell. Two separate mechanics in town tell me the driver's side head gasket is likely leaking or failing. They both did do the pressure test. I am inclined to fix the driver's side head gasket, leave the passenger alone. Truck is in good shape otherwise.
Between the two mechanics I look at my LX470 this last week, the first one is not convinced that I need a new engine - no check engine light, no misfire, smoke. The other mechanic has told me that there is coolant coming out of two of the plugs, and has already chattered about how costly a repair to the existing engine could be - he thinks I should take a serious look at a new used engine. For you all in the community here, what test(s) would be most helpful for you to know the results on? The new used engine estimated cost from mechanic #2 is coming in around ~$8k, whereas I am thinking if I caught this gasket leak early enough, maybe I am lucky enough to not need to get a new engine and can repair the driver's side gasket alone and call it a day.
Thanks for any insight you all can offer
Lexus or Toyota coolant are the same. They're either LL (red) 98-03 or SLL (pink) 04-07.
Did they give you pictures of leak?
Head gasket leak can be seen, unless between coolant passages and oil drain port. Which oil analysts can reveal.
Head gasket leaks, are typically due to overheating warping head.
That is coolant (pinkish crusty, outlined in yellow) leak for sure.
If it is the head gasket. 99.8% chance, engine was overheated. I find water hoses swollen, 8 out of 10 times, when that happens.
But point of leak, is not shown. I'd like to see pressure test blow it out where pink arrow is pointing at head gasket. The blue arrow points to rear water bypass joint on top of engine head. It also could be a leak, and come down block. Also notice the block drain in my picture. It too could be a leak. Just forward of pick crusty, is block water hose going to oil cooler.
But point of leak, is not shown. I'd like to see pressure test blow it out where pink arrow is pointing at head gasket. The blue arrow points to rear water bypass joint on top of engine head. It also could be a leak, and come down block. Also notice the block drain in my picture. It too could be a leak. Just forward of oick crusty is block water hose going to oil cooler.
Thanks for taking a look 2001LC. To confirm: you are saying that you would want to 'see pressure test blow it out where pink arrow is pointing at head gasket'? This would better pinpoint the issue on mine? Thanks
If there is a coolant leak into the head, does this necessarily mean the heads are warped? Could it just be the gasket that failed. Owner notes no overheating.
If from overheating. Not likely!
Many are driving around with engine running hot. Due to, improper coolant system service. Keep driving, and it will eventually overheat. Dash gauge may never show it or driver never notice. So, just because a driver states, he's never overheated. Doesn't mean he hasn't. If heads gasket leaking, is due to overheating. It's a safe bet heads are warped.
There have be reports, of head gasket just failing.
The CCN (car care nut) has a video, of a 25+ year old 4.7L very clean, reportedly very well maintained 100 series. He replaced head gaskets on. He used his straight edge to check head/block, they were within spec.
The reason he replaced the head gaskets, was coolant found in oil analysis. But he failed to find any drips/leaks into cylinder, during pressure test. Nor did he find any apparent point (witness marks) on head gasket, block or heads or any leak. He suspected the rubber coating on metal gasket delamanted, do to age. But, one would think, he'd find some witness marks or leaks. I posted a question to him: Did post oil analysis, come back clean. Showing head gasket corrected. No response!
I've also read, others say they "heard" of failures.
So we've hearsay and lack of evidence, reports of head gasket failures. Where heads weren't found or "reported (tested)" as warped, of reported as overheating.
https://www.blackstone-labs.com/
The pressure test on my LX had coolant leak out of the driver's side, but noted that no coolant getting into the combustion chamber. The test I think was done at 15 PSI (I may be wrong)
For sure, a head gasket leak. If was spotted at head gasket (pink arrow in above picture).
