Head Gasket job (total noob) (10 Viewers)
Somewhere
Hello,
I am complete noob in car mechanics , purchased the Land Cruiser 80 from 1997 with 240k miles and decided to work on the head gasket as suggested by Robbie.
I took off the air cleaner and am working right now on taking off the exhaust manifold. The question I have is - should the car be in the N on the transmission with transfer case in N ? I have it now on "P" and High.
I searched for this information and did not find it anywhere in this forum.
Regards,
Jorge
UPDATE:
The head gasket and all other stuff is done. Cruiser already went to the trail and I was happy to see it working out pretty hard. The temperature is around 182-185 Fahrenheit even when wheeling on the trail.
What I ended up doing during the head gasket job:
What were the biggest obstacles and frustrations:
If I were to do the same job again I would definitely take the engine out and do all the work on the stand. It was not very comfortable to spend hours on the engine bay even if the bay is pretty big.
  1. EGR - this was really pain in the ass. Both taking it out and putting it back. I spent two days getting the EGR nut out. Putting it back was frustration even bigger. To align the EGR valve was really difficult. I ended up putting a lot of force to bend the EGR pipe a little. I would suggest to put the EGR valve before the upper intake is bolted back. This way it would give you some room to wiggle the intake to align both EGR studs with EGR nut.
  2. TIMING CHAIN - really be very careful with the chain and the big hole where the chain is. If something falls down or the chain binds the timing chain cover would need to be taken out which means dropping both oil pans. Not really nice. If you rotate the crankshaft put tension on the timing chain so it doesn't bind on the gear down in the cover. Also be very careful that nothing falls down to the timing cover. Be very careful when taking the zip ties out !
  3. HEAD AND CAMS INSTALLATION - it's not difficult as it seems. Following the FSM is the gold here. I was putting the head two times as for the first time I forgot to put FIPG in the front of the head gasket. Be careful when putting the head back as I scratched the gasket when I was putting the head down and didn't align it properly. Be generous with oil and make sure that everything is lubed correctly.
  4. INJECTORS - I spent hours and hours on ih8mud going threw the threads of people describing their head gasket experience. There is high number of people who wrongly installed injectors which at the end were leaking. I still don't know if I installed them properly or not but I don't see any external leaking.
  5. EXHAUST - this was really PITA. I spent three days trying to take the bolts from the Y pipe (four of them). I ended up buying kano kroill penetrating oil which helped a lot.
What I wish I did differently:
  1. TAKING ENGINE OUT - I wish the motor was out many times. Firstly when the timing chain bound and I was looking to drop both oil pans. Second time when Robbie told me that the engine needs to be rebored at least and change the piston ring's etc. Spending hours and hours cleaning the block and piston I always told myself that I should have taken the engine out.
  2. TUNING - I don't know why but for some reason I didn't do the tuning when I had the head off. Now I would like to change the spark plugs, distributor rotor and cap, wires. All of this is much easier when it is out.
  3. TESTING ALL COMPONENTS - I did not test all the components. I admit that I cut the corners here and I must say that it is mistake. I should have tested the VSV for both EGR and EVAP. I didn't go threw the testing of the sensors and other stuff. Now I have intermittent starting issues which were also before the head gasket (hard start when engine is warm , fine start when engine is cold ) and I don't know if it is leaking wrongly installed injectors or bad fuel pressure regulator.
What helped me during the process:
  1. This community is amazing - a lot of people are listening and willing to help. Anyway I needed to do the homework first - reading hours and hours of threads about the head gasket repair was my daily bread for couple of weeks.
  2. Famous DVD - there is famous DVD from one of the member of ih8mud. I would recommend the DVD to everybody who wants to target this project.
  3. Local ih8mud people - asking for help in local clubs and finding somebody to help is not that hard. I was not dependent on the car which also helped. There was always somebody willing to come and help which is amazing.
Thanks again for all the support .
IMG_5781 by xsanch1, on Flickr
Jorge
You need a FSM. They have a pdf version on line.
In gear is fine unless you are on a hill side.
@jcardona1 did a great amount of detail in his thread, I also did a couple pics in my thread.
Well thank guys for your support, I admit that I am total noob anyway I downloaded the pdf version of FSM month ago and searched both in EM and SF sections. There is nothing mentioned about it in either ones so I suppose that it is fine if the vehicle stays in P.
Why in the world would the gear matter? You're doing a head gasket.
I didn't mean to come off as sounding Di€kish. I just can't see why even with little experience one would think a vehicle needs to be in a specific gear when not doing drivetrain work. Unless it's a manual transmission and you're messing with the crank bolt.
The reason why I ask is that during the process there is a need to set for example the first piston to top dead center. Moving the crankshaft I am not sure if that is possible only in neutral or not. Never did that and it's not mentioned anywhere so asking here.
Hello Jorge. Follow the FSM very closely and feel free to ask us any questions you may have without feeling stupid. The 1FZ-FE Head gasket (HG) job is a challenging procedure for any level of mechanic. Take your time and pay attention to detail. Once the head is removed you will have easier access to everything else in the engine bay so this is also a good time to inspect/replace many $ worth of other stuff.
Do yourself a favor and research a lot here on Mud ,and any other sources you find, before getting too deep into the job in order to learn about the mistakes others made, problems they may have had, and the long list of other maintenance/components operational checks/parts to replace "while your in there" and have the access and elbow room.
There are some good, complete engine rebuild threads you could glean some knowledge from as well.
Fighting with exhaust manifold bolts to y pipe. Got two bolts out and still fighting with other two bolts.
Went ahead and ordered AeroKroil from Kano and it should arrive tomorrow so will give it a try.
Also called CDAN today and ordered following:
  • head gasket kit
  • thermostat and thermostat gasket
  • water pump and gasket
  • some vacuum hoses
I will see how it goes.
Jorge
Kroil is good stuff. I also suggest a 50/50 mixture of automatic transmission fluid and acetone. Works wonders, leave it on overnight for best results.
X2 aft/acetone. Applied liberally to a frozen nut on my shock mount and 18hrs later it came off smooth like butter. My can of PB blaster just keeps collecting dust.
I had only CRC freeze-off which is not really good. What I bought and I think it was well spent money is gator grip. Sort of universal socket and very nice design. I also bought a mini torch today just in case of last resort.
Removing heater valve is there anything I should pay attention to ? There is a valve control cable not sure if that needs the treatment as throttle cable i.e. mark it's position.
Heater valve cable does not need to be marked, it just slides out of the lever and will hang there until you put a new valve in and hook it back up. Now is the time to replace the heater valve if you haven't planned on it already; the side pipes tend to corrode with age and can snap without warning.
I removed the fan , that was PITA. I don't have multiple 12 mm wrenches so could not use two of them to take those four bolts out. I ended up putting a lot of tension on the belt and remove the two upper. Then I released the tension and rotated the water pump pulley to have the lower two fan bolts on the up side and put the tension on the belts back. Now I have all four bolts off but the fan is still holding strong.
