Hard front brake lines for truck and 4Runner NLA
Juneau, AK
After finding part number for one of these lines , 47313-35790, I've discovered it's a discontinued part.
Is there a good substitute anyone knows of besides bending a line from parts store?
Looks like the drivers side hardline from the master down to the frame. I’d think the best option would be newer generation pickups and 4Runners. While I don’t have a definite answer if something will directly bolt up, I’d be willing to bet you will find something pretty close that would require minor modifications… but I’m sure you already know this
No, it's just a very short hard line right before the caliper and beyond the soft line.
just get them from something else. ive used several different styles. try 3rd gen 4runner or same era taco. probably most any of these trucks are similar enough
If you find yourself HAVING to bend up a line like that, get some NiCopp tubing to do it. SUPER easy to bend without kinking. Get some of those brake line pliers for bending in tight spots. Extra bonus is that it won't rust.
do you use Toyodiy.com or partsouq for searching parts?
appears those parts are still available. just curious where you found your nla numbers?
Damn. I did check partsouq and my search came back not available. Perhaps I was using an old, superseded part number. Thank you.
That almost looks like the whole axle line.
probably not for $3.
i used the pn from his yotamasters link.
Sorry. Typo. That looks like the line used on solid axles.
