Media GX470 Wheel/Tire/Lift Picture Combination Thread (10 Viewers)
Photo/Video/Audio threads
Icon 2" lift with KMC XD wheels and 285/70/17 Geolander A/Ts. I may also be taking off the factory running boards soon as I'm tired of their cheap plastic look.
I also liked the look of itrack's bronze wheels on a gold GX, but went with gray.
The Icon lift gives a very relaxed and comfortable ride, and is fantastic offroad. I picked the Geolanders for a good compromise between onroad quiet and offroad performance. They are indeed very quiet onroad and should be good in snow as well.
I'm brand new here! I've been watching from afar for quite some time now but finally pulled the trigger on a clean 05 GX over Labor Day weekend. Can't wait to hit some trails!
OME 2.5" lift
TRD Pro wheels 17x7 +4 offset
285/70/17 KO2s
You and I are almost twins! I'm on Bilstein 5100s up front with a 1" spacer and failing airbags in the rear. Ordering rear conversion with OME 2895 springs for the rear this afternoon.
Tires are 265/70-17 Duratracs
1.5" spacers
^ I also have the SR5 wheels on mine. Like them a lot!
whoa almost been 1.5 years since my last post in this thread. been a few changes.
Wheels: Hostile Podium H112 17x9 -12
Tires: Kenda Klever RT 35x10.5R17
Spacers: None
Lift: OME 2.5"
Other Mods: Body Mount Chop
1.5" spacers
With the 1" spacer, did you have to trim the stock studs? I test fitted BOREA 3/4" spacers this weekend to hopefully clear my 275/70/17 on 5th Gen Trail wheels and I would've had to cut them...
OEM wheels have pocket behind it. It clear with no issue.
I have 1 1/2" wheels spacers, so no issue there. The 1" spacer is a strut spacer on the top.
Dobinsons springs/struts. 2" front, medium springs. 1.75" rear, heavy springs.
TRD Pro SEMA wheels.
275/70/17 General Grabber ATX. E rated.
- No spacers.
- Fender liner mod.
- Little bit of bumper corner cutting.
- Little bit of running boards cutting.
- There was front and rear rubbing on turns, not even on full lock.
No lift, but I did finally get around to ripping off the running boards last week. Man, I don’t miss those at all. 265/70R17 BFG KO2s, and 2019 SR5 wheels.
Just hit 200K and starting Yoshimi’s (Yoshi) transformation from daily hauler to camping hauler.
KMC Dirty Harrys
BFG KO2 265/70/17
No lift (yet)
No rub unless full compression and full lock
Dobinsons C59-314 front springs
Dobinsons C59-325 rear springs with 10mm top spacer
Enkei RPT1
18 x 9
0 offset
Yokohama Geolandar X-AT
275/70R18
My driveway has an incline, but the GX has a 0.75-1" rake. When loaded for camping it is level.
How do you like those tires? They look like they would be louder than BFG but quieter than STT.. ? I'm about to buy 4 for my Lexus
thanks for any word..
