Media GX470 Wheel/Tire/Lift Picture Combination Thread
Photo/Video/Audio threads
e28
Red Deer Alberta
Another forum I am on has a thread like this and I found it extremely
helpful in picking tires and lifts.
For those who would like to contribute, post your combination of the tire size/brand/type including lift and any modification to fender, running boards, liners or bumpers. If you have bumpers it would also be helpful if you would post where you got them and what brand they are. You must follow the format along with a clear shot of the side of the GX, (and front for those with spacers).
No chit chat
Refer questions to private messages, build threads, or General Discussion 120 forum
Example:
Wheels: Stock 17"
Tires: LT265/65-17 Discoverer STT
Spacers: None
Lift: None
Other Mods: None
Side Image
Front Image (If applicable)
Wheels: Stock 5th gen Trail Edition? 15mm? They came on it and I'm new to Toyota's
Tires: 265/70R17 Bridgestone Dualer H/T
Spacers: None
Lift: None
Other mods None
If you want me to remove your GX or edit something let me know.
bobinsofla
Wheels: Stock 17"
Tires: ? LT265/65-17 ?
Spacers: None
Lift: Ironman 2" lift The front is the regular white FEC shock and suffix B firmer spring. The rear is FEC Pro (black) shocks and the suffix B firmer spring.
The ride is good. It's a little different in that it can seem a little "jouncy" over some bumps versus the stock suspension, but when you hit heavier/harder bumps or holes, it soaks them up much better than the stock airbag suspension did.
Other Mods: ?
gx470-ironman-lifted-3-jpg.1047723
Coop's GX470 Coop's GX470
Wheels: 17" 4Runner SR5
Tires: 265/70R17 Dick Cepek Fun County bit large for a 265/70/17 measuring out at 32" tall and 10.7" wide
Spacers: None
Lift: MetalTech GX470 long travel coil springs, which says they are a 3" lift and no more rake lift;
Metal tech long travel HD springs, with new upper & lower rear control arms, long brake lines and a Toytec pan hard bar. 2" lift in back and just under 3" in front. I have a small rake still 1/2" difference
Other Mods: RCI full skids and sliders
image-jpeg.1301640
mtwilly87 CO GX Slow Build
Wheels: Stock 17"
Tires: 265/70r17 General Grabber AT 2s
Spacers: None ?
Lift: 2"? Iron Man Pro Cell Foams
Other Mods: None
img_0243-jpg.1376250
scparrish 08 GX Slow Build
Wheels: Stock 17"
Tires: 33.5"x10.5" BFG KO2
Spacers: spidertrax 1.25" spacers
Lift: Standard travel Icon coilovers with re)mote reservoirs 2" Icon springs (On Stock Wheels/tire size ground to fender it measures at 38" in the rear and 37"
Other Mods: ?
imag0521-jpg.1230770
Build thread in sig
Wheels: Method 17x8.5 4.5BS -12 offset
Tires: 34"x10.5" BFG KO2
Spacers: none
Lift: Icon 2.5 extended front (non-resi) with TC UCA and LCA, S2 resi/cdc secondaries, spindle gussets, readylift billet tie rods, MT LT rear with LT icon 2.5 resi cdc, FJ antirock swaybar, Icon expedition springs (about to go to LT spring)
Other Mods: Lots
Wheels: FN Six Shooter 17"
Tires: Cooper ST MAXX 265/70/17
Spacers: None
Lift: 2" Radflo/Eibach Metaltech package
When I was trying to decide on tires/wheels/lift I found it very frustrating to sort through pictures on forums, so I created a website, Meta4x4 that saves pictures w
ith meta data for easy searching of brands and sizes. Unfortunately it only has pictures from me and one of my friends right now so it isn't very useful. Here's a link to my GX so that you don't get lost in my friends Nissan XE 4wd wagon pictures: Meta4x4
2006 GX470 with Bilstein 5100 in the front and 5125 in the rear. Factory springs on 3rd from the bottom perch on the struts. 895E springs in the back with Southern Style Offroad conversion without either of the 1/4" shim spacers(3/4" lift).
275/70-17 BFG AT K02 on factory wheels with 1.25" SpiderTrax spacers. Full size spare does fit...barely.
Currently after 5 days and 250 miles.
Front
22" hub to fender
Rear
23" hub to fender
FOX 2.5 Extended travel front, Fox 2.0 Extended travel rear Toytec HD rear coils Total Chaos UCA's FN Wheels fX pro 17x8, 315/70/17 Nitto Terra Grapler MT . 3 inch suspension, 1 inch body lift custom coil conversion with Firestone airbags tied into factory load leveling system, Sway bars removed Timbren of road bump stops front and rear. 4 year ongoing project.
y4micbXUs0Y4O6G_XDVBqmYskyjxtU36lVvx9ormsXRnHzLBYxKx0zXlyjJ6MtgT1T6wTJHfZfWOQ0tiX9S3W8IFaT66wkuUTSf2WwX9FWl65NsOIFXHUiMuQL9N-hQopyOzP3deZ9i1ssbdsNul9IYeTAEQ4Df2QkO6_wYNMMsnq05Baet4E9F1KYVX8i1VnOn3HOpH37jLwE9WzRq0MhmBg
Firestone Destination AT 275/70/17, 2.5" lift
Probably the best all around tires I've had.
