I think its about time we have a pic thread of our vehicles on here. Here is mine, 2010 gx 460 with the running boards off and then shortly after OME 3" Lift. Im waiting on these tires to run their time and then i will be adding some BFG KO2s
I've done a few things since the lift when I first posted: 285/65/18 ko2s. Yakima cross bars, ARB Awning, and an unbelievable trip across the country to Moab and Telluride area
Your ride looks great! How did you get the 285's to fit with stock wheels? Are you running wheel spacers? People have said even a narrower 275/70/18 will make contact with the upper control arms on stock wheels. They are a tiny bit taller though, 33.2 vs your 32.5. Maybe that makes all the difference?
that gray GX above with the travel trailer is a 2014 Luxury with the air suspension. The trailer is just under 5000 pounds so I do not use a weight distribution hitch. The air suspension levels out the GX and it pulls fine up to 60 mph, would probably go faster but I have no need to try. I have to use a 6 inch drop hitch turned upside down to get up to the height to keep the trailer level as the GX hitch is very low and trailer has a lift kit. I installed a Tekonsha 3 brake controller using the supplied brake wiring adaptor from Lexus and it works flawlessly. Brake controller is mounted near left knee to avoid the knee air bags on right side. I get 11.5 mpg while highway towing.
