GX460 to Prado 150 Resource Thread
Tulsa, OK
***Not Complete, consider this a DRAFT list of stuff needed***
**Prices are based on what I pulled yesterday 9/14/23, will probably change**(pulled price from cheapest warehouse)
I had a small fender bender this past week and was considering a Prado - swap. Still on the fence based on effort and time but thought I would share the results of my research. The kits from China are tempting but hard to tell quality with out seeing them in person. The other build threads didn't seem to post part numbers, so I figured I'd start a new thread. I think turn key though, the kits will be cheaper, especially if you want to do front and back. My plan was to do front all OEM, and for the rear, just the license plate surround, and eBay rear tail lights.
Here are what I got through comparing assembly part numbers part by part in each section. I had Megazip on one monitor, and a Lexus dealer on the other. Based off what I pulled off of my truck when assessing the damage, tried to do a through review, may have missed some things. I figure this can be a resource thread for those that need, and as you confirm what works or what didn't post it up. This is about 3 hours worth of work, but a good starting place.
Different trims are going to make it easier or more difficult. I have a premium, so the main gap for me is the headlights, they need to auto level to not throw a code, I think. I had a hard time finding if which 150 trims have that, it may be just the Kakadoo, as it's the only trim with airbags, but not sure. Maybe one of you do?
Also, really wanted to find headlights and grill from the newly release Matte Black trim, but didn't find much, I think they are UK, Singapore and Japan only, but not sure.
SectionPart TypeBOM QtyNeeded for SwapPrado PNMegaZipWare-houseGX PNNotes
HoodHood Strut Left
1​
153450-0W230$ 77.17JP53450-0W180These are different
HoodHood Strut Right
1​
153440-0W270$ 77.77JP53440-0W220These are different
HoodHood Sub Assy
1​
153301-60630$ 370.09UAE53301-60640
HoodInsulator
1​
-53341-60360$ 134.53JP53341-60360Same Reuse
HoodInsulator Clips
11​
-90467-09050$ 0.9690467A0003
HoodHood Seal to Rad Support
1​
-53381-60140$ 3.92UAE53381-60140
HoodClip for above
1​
290467-08011$ 0.28UAE904670801183
HoodHood Plug
1​
290950-06096$ 0.79JP90950-06124
HoodHood Leading Strip
1​
175770-60020$ 47.45Nanot on on the lex
Hoodhood hinge left
1​
153420-60070$ 22.83UAE53420-60070
Hoodhood hinge right
1​
153410-60080$ 22.05UAE53410-60080
FenderRight
1​
153811-60A90$ 265.03UAE53811-60C80
FenderLeft
1​
153812-60C10$ 274.91UAE53812-60C30
FenderSeal Right - should have clips
1​
153807-60110$ 33.55UAE/JP53807-60150
FenderSeal Left - should have clips
1​
153808-60090$ 33.55UAE/JP53808-60100
FenderLiner/Splash Shield Left
1​
153806-60060$ 60.75UAE53806-60100
FenderLiner/Splash Shield Right
1​
153805-60080$ 63.70UAE53805-60110
FenderLiner Extension Left
2​
-53851-60200$ 18.87uaeSame Reuse
FenderProtector Fender Left
1​
-53828-60060$ 30.23JPSame Reuse
FenderProtector Fender Right
1​
-53827-60040$ 28.64JPSame Reuse
FenderScrew with Washer
2​
-90159-60496$ 0.44JPSame Reuse
ApronAir Deflector Right
1​
153293-60160$ 47.36UAE53293-60111
ApronAir Deflector Left
1​
153294-60160$ 44.55JP53294-60121
ApronMember Sub-Assy, Front Cross
1​
157104-35061$ 85.29UAE57104-35061Same Reuse
ApronBrace Sub-Assy, Hood Lock Support
1​
153209-60150$ 29.38JP53209-60141Same Reuse
ApronPower Steering Cooler Line?
ApronCooline line brackets
Apronlock Assy, Hood
1​
153510-60370$ 33.89UAE53510-60321LHD
BumperImpact Bar Sub Assy (Alum Bump)
1​
152021-60231$ 346.53JP52021-60260
BumperImpact Bar Bracket
2​
-52026-60050$ 44.29Same Reuse
BumperStyrofoam Absorber
1​
152611-60120$ 22.81UAE52611-60080
BumperLower Front Cover (Lower Valance)
1​
152129-60040$ 59.81Uae52129-60020
BumperUpper Center Retainer / cover support rail
1​
152521-60150$ 40.77UAE52521-60120
BumperRight Bracket Sub Assy Right
1​
152102-60270$ 19.19UAE52102-60260
BumperRight Bracket Sub Assy Left
1​
152103-60270$ 17.54UAE52103-60250
BumperBumper Reinforcment Stopper
1​
152148-35120$ 15.20JP
BumperCushion
1​
152462-52040$ 1.14JP
BumperCover / Skin
1​
152119-6B922$ 264.22UAE52119-6A952
BumperSupport Left
1​
152116-60240$ 25.00UAE52116-60210
BumperSupport Right
1​
152115-60200$ 28.06UAE52115-60210
BumperFoglight Trim Left
1​
152128-60160$ 18.07UAE52040-60030
BumperFoglight Trim Right
1​
152127-60170$ 18.22UAE52030-60030
BumperLower Grill1153112-60200$ 49.49UAE53112-60100Right
Bumper53113-60050Left
HeadLightsheadlight washer nozell passenger
1​
185044-60150E1$ 22.14Local85044-60150E1
Bumper2 new parking sensors?
2​
289341-48010-C2$ 113.57JP89341-48010-C2
HeadLightsRight
1​
1$ 750.0081145-60E91
HeadLightsLeft
1​
1$ 750.0081185-60E51
HoodHood Strut Left
1​
1​
HoodHood Sub Assy
1​
HoodInsulator
1​
HoodInsulator Clips
11​
1​
HoodClip for above
1​
HoodHood Plug
1​
1​
Hoodhood hinge left
1​
1​
FenderRight
1​
FenderLeft
1​
1​
1​
1​
1​
2​
1​
1​
2​
1​
1​
1​
1​
1​
1​
2​
1​
1​
1​
1​
1​
1​
BumperCushion
1​
BumperCover / Skin
1​
BumperSupport Left
1​
BumperSupport Right
1​
1​
1​
1​
2​
HeadLightsRight
1​
HeadLightsLeft
1​
Would you do the Prado rear spare tire door also? I don't see it listed.
No, personally want the 'flat back' and keep the rear glass that opens.
Intent of this is to inform, and for anyone that has done the research to add to it here so we can collaborate if you want OEM Parts
I believe you can just unplug the headlight computer so you dont get the error and you can go to the lower priced headlights without auto leveling
Are you referring to disabling the AFS by removing a fuse? If so, I tried that and it didn't work. The fuse for the AFS is associated with too many other functions and is not a stand alone fuse.
If I were to do this, I'd rather keep the AFS, I think the 150 Kakadoo trim with airbag suspension in the rear should have it, just don't know which headlights those are.
Based on PRICE, $1,225 Each (yikes)
81145-60J20 Right
81185-60J20 Left
But, then also want to make sure they are LHD aligned.
Ok, definitely can go OEM but shipping is the killer. Mega zip said they can combine shipping but just a few of the larger items is pretty high.
Ended up going the Alibaba route, will see how it goes. I'll post result but don't know how transparent to be as to not disrupt Alpha Offloads site, although he wasn't responsive to my pings.
Along with some buds, I ordered some front ends, rear doors and extra grills and snorkels. We'll see how it goes.
