grinder: 4" or 4 1/2" ? HF?
e9999
Gotta get out there...
Moderator
US
I've seen both 4" and 4 1/2". Which is better to get? More choice in disks? Can one use 4" disks on a 4 1/2" or are these different mandrels?
Seen both size grinders at HF for something like $17. Way less than the usual $50. Worth getting if only to use a few times before it conks out or is power a serious issue with these? (thinking about doing the front control arms themselves if needed and their brackets on the 80 for the caster plate job...)
I have a 4 1/2 sears/craftsman grinder. I did most of the cutting & grinding fabrication on this bumper with it. I was pretty impressed. 4 inch and 4 1/2 inch have different mandrel sizes. I've never used a 4 inch, but depending upon what you're doing, the 4 1/2 inch has a small enough work surface as it is...I'd go with the larger one.
I have the HF grinder. It is ok. It has enough power. The casing isn't really tough though, but has lasted me over 3 years and about 15 wheels. It comes with extra brushes, but I used them to repair the FJ62 heater motor.
I bought a cheap tool box to keep it in.
I think that the spindle (arbor?) size is more important than disc diameter. We have a Ryobi at work that has a very small one and it's a pain to find the right size discs for it.
That's a hell of a nice looking bumper.
I would go 4.5". Disks are easy to acquire at Lowes :grinpimp: , or if you are desperate, Home Depot :mad: . I've been though two DeWalts on my FJ40 project. When this one dies I'll go either Milwaulkee (first choice) or Hatachi (little less power, but recommended by a buddy).
Either way.
I have a Bosch 4" that spanks My HF 4.5" angle grinders, but honestly, you can get the HF ones for $9.00 each. I bought 4 and have one for each type of grinding/sanding/wirewheeling...
Makes it quicker.
and yes, the arbor size is different depending on which size grinder you use.
i like my HF 4".. Im going to buy a couple more so i can have one for each cutting, grinding, sanding. etc.. if one dies, i just get another one for $10.. i Use HF Cutoff wheels and Disks.. Cheep Cheep Cheep.. but gets the job done.. i could have 4 Grinders all setup with Disks for less than a Dewalt..
OK, so 4.5" disks are cheaper/easier to find than 4" ones then?
when / where do you get these HF grinders for $9? I saw them at $17 or so a couple of days ago. Do these go on sale regularly?
damn, how is it possible to make something like that this cheap? These things must be bought for like $5 in China...
Well, I've got a $9.99 HF (blue 4.5 inch) and one of the $14.99 ones and I would get the $14,99 orange one over the blue one...
nothing more annoying than when the HF grinder finally craps out on you mid job though.. I bought a cheapie one at Home Depot Ryobi. That one was OK but died after a couple months of regular use. Had it "fixed" under the warantee and still barely works, I use it for cleaning welds only with a wire wheel. Then I have a MIKITA $60 home depot unit that has been to hell and back many times and is still holding up like it was brand new. So that is my recommendation...
Also, 4.5" I wouldn't even consider 4" IMO...
that hf grinder developes 3.3 PEAK amps:rolleyes: :rolleyes: :rolleyes:
you should try and get ATLEAST 6 or 7 amps, with the more the merry, and longer lived.
yeah you're going to pay closer to 100bucks.
home depot
ridgid 4 1/2 grinder
89.97
10,000rpm 8amps (amps are more imporant that rpms)
these grinders are the shizzle
for garage work, this will be the last grinder you buy period
i have two of them in my truck, they spend most of the time in muddy trenchs choaking on small rocks and swiming in puddles.
yeah i've killed a few but umm:rolleyes:
I just picked up the HF grinder today, but I decided to splurge and get the $17 version. 4.5 amps, 11,000 rpm. Some people have mentioned the orange ones are a stronger and last longer, plus, i've had good results using the orange ones. I'm mainly going to use it for the wire wheel but there was a sale on 10pc grinding disc set for $5, so I picked that up too.
For $17 it's a great deal. It's stronger than I would've thought. First thing I tried was a 3" wire cup wheel to grind away some rust. Not so good. The wire wheel just isn't balanced enough for the grinder, so it's like trying to hold on to a jackhammer with all the vibration. I just can't hold on to it for more than a minute before my hands become numb. Swiched to a regular knotted wire wheel and everything works fine, although the guard is a little bit small for a 4 1/2" wire wheel. a 4" wheel is probably better for it. I'll probably pick up a few more, at this price I'll have one for each type of disc I want to run.
splurged too and got also the orange one, since you guys insisted...
4.5A still quite a bit less than the Makitas, Craftsmans, and Milwaukees I've seen around, but it was $18 on sale - 10% so not too bad... 10% coupons on just about everything in the store...
10 packs of wheels on sale too on the web site.
We'll see how it holds.
