does any one have a map of all the grease fittings on a 97 lx450
thanks for any help,
Garett
Garett
Every oil change. Or after you go through a bunch of water.hmm i did not know that ...and how often should we be greasing our 80's
Garett
I'm going to bump this back to the top. It seems I will have to take the shaft down to grease the front U Joint on the rear shaft. I tried with the straight on and the 90 deg and just can't get it on enough to get that damn little zirc. Before I take the shaft off, thought I would check to see if there are other suggestions. Google did not return any couplers that seemed like it would work.
if you turn the driveshaft so that the zerk is pointing upward (toward the floor pan) at about a 12-2 o'clock orientation.
I'm going throught the truck, doing some p.m. that I don't think had been done in a long time. How do I clean old, nasty grease out without putting too much grease in?
