This^^^^. Those valve pushrod covers are notorious for leaking oil, especially towards the rear of the engine near the exhaust down pipe.I agree with PistonPete. Looks to me like the valve pushrod (side) cover is more than likely the problem.
As others have said clean that puppy up so it shines and then rule out all the east stuff. Assume the head gasket is fine until you’ve eliminated the possibility of a leak from everywhere else.What should I do? It’s not consuming it. It’s leaking out, extremely slowly. To my understanding, doing head gaskets are a big job on these.
Lol I have done head gaskets on other Toyota engines. This one looks the hardest, I’m serious.Then pull the head !! Put a new gasket and check the precups ! engines out, easy peasy...
I don't remember anything particularly hard about the job (its been a few years). I seem to recall a 22RE being harder just because of all the fuel injection stuff. Do you have a shop manual? If you don't you should get one. You probably could down load off mud - seems to me I've seen it offered but not sure if it still is available and where.
Like pistonpete should be relatively easy and then new gasket and check precups ( I would just change them). Or alternatively, install everything get it running and change head in truck - still not that hard - but its a heavy little sucker!
nice, good job
head gasket on the 3b is super easy, especially with it out of the truck,
the problem is you WILL find things ie, a cracked head..... cracked precups are a 100% probability but the head being cracked is also highly likely ( mine was as are many )
this is the kind of thing you need to know before just chuckin an engine in and running it, you dont want to drop a precup, and they are a wear item like a timing belt.
Im up in pg, i have 2 3b 70series, let me know if i can help
Radd cruisers is a good resource for us, fast shipping and they are knowledgeable and have much more than is listed on their site.
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
forum.ih8mud.com
