no torque reading unfortunatly - I'd've liked to get a full torque/hp curve but it was getting too hot. Maybe next time.RUSH55 said:Whoa!!! Did you get a torque reading?
RUSH55 said:Now, was this hp reading at the flywheel (did you pull the engine?) or at the rear wheels?
Mace said:What dyno?
Mace said:145 RWHP,
I need a better cam badly..
Course, the 40's/14bolt/2 tcases/sm420 and the fact that I have never adjusted the valves and am running VERY rich in the propane dept... might have something to do with it too![]()
Unfortunately it does not work that way with a draw through systemandrewfarmer said:I had mine on the dyno because I'd had to replace the LPG regulator. The new one allowed me a much shorter hose to the mixer, and more importantly, got rid of 2 tight bends in the hose that were restricting the gas flow.
When we ran it up, I had to close up the power valve about 3 turns to get the mixture correct (at high rpm) from what had been the correct rate with the old reg and hose.
I also turned about 3mm out of the mixer (increasing diameter).
These changes only (and the fact the motor is run in now) nett me an increase from 135kw to 163kw.
Of course, if you're runniong too rich, maybe you just need to increase the boost to compensate!!
RUSH55 said:Andrew, in power or torque measurements, what is kw?
