Nine months in....
Well, I've had the truck for almost 9 months now - coincidentally the gestation period for humans - and time to take stock. I've gotten familiar with her and she is definitely a keeper!
My future plans for her have changed. Initially I was keen to get to do the frame-off restore as soon as possible, but I am now going to delay that as long as possible. It has become very clear that if I want to go down that road I am going to need to have all my ducks in a row beforehand, can't afford to do it half-heartedly or to wait for huge amounts of time for parts. I have compiled a list of all the stuff I have done so far (more for my own benefit), and a flexible list of things I am planning on doing. I look at all the other rebuild threads with amazement, the amount of love and dedication that goes into those - my little bits seem so lightweight. But I'm on the lookout for an older sister that will need more work………I might catch-up sometime
My daily driver has been in the garage for the past four months, but now she is back on the road, I've been working interstate for most of the time but about to head back home - so just in time. Most of the work has been on the interior, but even so the ergonomics are not much better (was that even a word back in 1984?). The LX seems to be quite a bit more complex with all the, er, luxury stuff. I am so enjoying this journey, the truck is so old school - takes time to get the parts, time to get the money, time to fix the bits - no such thing as instant gratification but the anticipation is probably part of the joy hey?
Nine months to get this all done, OEM parts used where replaced:
⁃ Serviced (new oils, new filters, and a once over)
⁃ Repaired battery tray, resprayed tray and bracket, new battery
⁃ New brake master cylinder (non OEM)
⁃ New brake booster gasket and repaint
⁃ Rust touch-up on interior (not much, but the little bits that were there have been treated)
⁃ Touch-up paint to little scratches on dash
⁃ Weld crack on floor around driver's seat
⁃ Rear door lock - cleaned up, tightened, new spring
⁃ Rear number plate holder powder coated, new light holders and globes
⁃ Refurb A/C unit - cleaned up motor and fans, new foam and rubbers, ran wiring harness behind dash, fitted rear bracket, cleaned up control box and powder coated brackets
⁃ Refurb heater - powder coated unit, flushed and welded core, new foam and bushes, cleaned ducting, powder coated pipe protectors
⁃ Fitted new radio - ran new wire harness from fuse box, fitted noise suppressor, new wiring to speakers
⁃ Extra wiring harness for future accessories - ignition, battery and engine power leads run to glove box
⁃ Refurb dash - polished and painted the knobs, cleaned up all switches, polished tightening collars, lubed vent and heater cables, fixed clock bracket, touch-up bare metal on rear of dash
⁃ Refurb speedo cluster - cleaned up odometer, new foam, new globes, touch-up paint on bare metal, repaired intermittent wiper timer
⁃ New gear shift bush and seat, new spring and cover, new rubber boot, powder coated lever, cleaned up external boot, refurb transfer shift boot
⁃ Seat rails - powder coated, cleaned up bearings
⁃ Cleaned up front plastic mats - cleaned about a golf-ball size amount of sound deadener off the bottom!
⁃ Fitted new carpet to rear, new rubber mat underneath
⁃ Cleaned up rear plastic trim, replaced a few plastic lugs and fixed a couple of cracks
⁃ Bought and fitted rear jump seat bracket, armrest, seat belt - no more missing bits
⁃ Seats got a good cleaning and so did the toolbag
⁃ Most interior bolts have been yellow annealed, and brackets have been powder coated - look good as new
⁃ Yellow annealed the door striker catches, new fastener screws and captive washers
⁃ New bolts on rear door latches to replace rusty ones
⁃ Cleaned up firewall sound deadener, added sound deadener to front floor
⁃ And other odds and sods like grommets, cleaning up fuel sender, found the spare key behind the dash pad, lots of 20c pieces, years of dirt, and created new swear words when I dropped the gear shift bush into the gear box………
Still to do in the very near future:
⁃ Finish spray of the hand brake - first attempt was a mess, seems the different rattle cans did not play well with each other
⁃ Fit new OEM steering column cover that I picked up cheap
⁃ Weather stripping for front and rear doors
⁃ Clean headliner, looks like she will come up good
⁃ Check for the electrical gremlins - get ammeter to work and get to the bottom of the glowing sedimenter light at low revs
⁃ Find bits to complete the OEM toolkit
⁃ New battery tray - the old one is approaching it's use by date
⁃ OEM lenses for rear lights
⁃ Upgrade headlights
⁃ Replace brake bleeder nipples, refurb front brakes
⁃ Refurb clutch master and slave
⁃ Find an OEM driver door handle to replace the cheap knock-off
⁃ Headrests probably need replacing eventually
⁃ Fit new hinge to replace bent one on the RHS ambulance door
⁃ Track down the clunking sound my front suspension makes when I turn corners
⁃ Start collecting the decals and rubbers for when I do eventually do the frame-off
⁃ Decide if I want to keep the monster bull bar or replace it with the OEM bumper
⁃ Continue to drive her daily……..
I'll add a few pics in the next post……
