You guys gonna pull the head and see if you can find some internal problems or culprits I presume? I'm curious as to how the motor now turns over after divorce. Are you planning on taking the trans in for a diagnostic too?
I would rebuild itMy bay is getting a little crowded.
It is time to start putting things back in instead of taking them out.
On that point, I have to take my old 292k transfer case off the old transmission and put it on the 72k transmission. Should I (as I suspect) rebuild and or service the transfer case before I mate it to the transmission and put it back in?
Thanks for the tips. I will check the classifieds for the guy in Asheville.
Yes the cylinders still move and there is compression or at least the previous owner says that when he cranked the engine after the gear broke it turned very very slowly (compression). I have turned the crank by hand and the pistons still move freely. I am just kind of freaked out about a 292K motor. Is it cost effective to rebuild such a high milage motor or not? I'm not sure.
