- Thread starter
- #61
While I explore an alternative, anyone got a line on 42601-60262-03? Need 4, maybe a 5th. I hear a legend by the name of cdan was able to order some for a few folks, but that was a while back.
I’m running “narrow” 35” tires.
Common width is 12.5”.
The narrowest 35” tire I could find were 11.5”.
Nitto TrailGrappler.
I am very happy with the tire.
Jsmo, this is great help. I’ll run a 235/80 or a 255/80 if budget allows. Flares are coming off. This is my second 80, and I’m looking for a different experience than the first. Running narrow and light Is the goal.I ran those Tacoma steelies years ago with 255 85 16 bfg km2’s and no wheel spacers. Did not have flares at the time so the wheels lined right up to the edge.View attachment 2188657
oops, meant 235/85 or 255/85Jsmo, this is great help. I’ll run a 235/80 or a 255/80 if budget allows. Flares are coming off. This is my second 80, and I’m looking for a different experience than the first. Running narrow and light Is the goal.
I agree the 255 is likely the ideal and I would lean to a 255/85/16, but limited choices means $$$ for a set. choices for most are around $250 a tire. In comparaison, in the much more competitive 235/85 size, a good tire is from 125-175. I need to get 5, all tires are shot on that cruiser I got. The 235 is also found on many shelves, and I can match my trailer later on to run the same tire255/85 16 - The proper 33" tire for an 80.
Unfortunately, the Ironman brand does not make their M/T in that size, tho it's tread pattern appears to be the most practical for many different terrains, excluding snow (too few sipes, if any).
Just be sure to see the 235/85's mounted first. Like another said previously, beading a 235 on an 8" is dodgey at best. And after I saw them on another ride, they appeared to be entirely susceptible to falling off the bead in moderate to extreme side loading. And I think you'll also be limited in how much you can air down for the same reasons.I agree the 255 is likely the ideal and I would lean to a 255/85/16, but limited choices means $$$ for a set. choices for most are around $250 a tire. In comparaison, in the much more competitive 235/85 size, a good tire is from 125-175. I need to get 5, all tires are shot on that cruiser I got. The 235 is also found on many shelves, and I can match my trailer later on to run the same tire
the 235s would go on the same Tacoma 16x7 steely jsmo posted above. I find comments for the Milestar Patagonia in 235/85r16 reported to be a full 32 inch mounted when new. I think I’d be happy with that.Just be sure to see the 235/85's mounted first. Like another said previously, beading a 235 on an 8" is dodgey at best. And after I saw them on another ride, they appeared to be entirely susceptible to falling off the bead in moderate to extreme side loading. And I think you'll also be limited in how much you can air down for the same reasons.
Yes, 255/85 16's are expensive and usually special order too. Interco TSL's come in that size for a little under $200/ea, but their sidewalls are not as robust as BFGs. Same with Goodyear M/T's - soft sidewalls. But that may not be a deal breaker for you, being in FL clay.
forum.ih8mud.com
I see. Copy that.the 235s would go on the same Tacoma 16x7 steely jsmo posted above. I find comments for the Milestar Patagonia in 235/85r16 reported to be a full 32 inch mounted when new. I think I’d be happy with that.
Pretty sure you can't use the word "light" when referring to an 80.Running narrow and light Is the goal.
