- Joined
- Nov 14, 2013
- Threads
- 67
- Messages
- 576
- Location
- Huntsville, AL
- Website
- www.rocketcitycruisers.com
Guys, i have been fighting with my 80 ever since i put the lift on, for reference i used the OME 2". I had a bad vibration and humming noise coming from under the truck from about 30mph+. I did some research here and found most people were suggesting the OME front control arm bushing offset kit (OMECA77B) which i installed and that seemed to fix the front end vibration. So one issue down, but i am still getting a lot of driveline vibration from the rear end, which i have isolated by pulling the rear shaft out. I have already done U Joints and had the shaft balanced but to no avail. I have done the trans mount as well but that didnt change any thing. The rear flanges are level with the ground so i dont think i need adjustable rear upper control arms but maybe. I talked with the folks at SLEE yesterday and he said i probably need a new rear driveshaft and recommended going OE toyota but i was just unsure what that would fix if the UJoints are new.
While i am picking brains, my truck leans to the left about 1.5". Have seen 1" spacers to help fix that, but the guy at SLEE said that i have the springs installed on the wrong side. The OME springs i bought werent labeled left and right so i was confused. Anyone know anything about whether they are side specific?
