For Sale FZJ105 project in Boise, Idaho - new 1FZFE coil pack long block and much more! (1 Viewer)
Year
2000
  1. 100 Series
Mileage
10
Color
rgb(9, 47, 16)
It will take me some time to do a complete listing here on this for sale ad. I am getting it started now though.
About a year and a half ago a customer started acquiring Cruiser things to build a 105-series. He has decided to cancel the build since he has a lot of Cruisers and wants to take a break from builds for awhile. I am sure he will chime in here in this for sale ad but I will leave that up to him. We here at my shop have helped acquire a lot for the build as well as stored all the goodies. The only thing not here at our shop currently is the actual 100-series.
First up; the plan was to build a FZJ105 using a new 1FZFE coil pack long block we had found along with an H151 manual trans and a HF2A full time tcase, the trans and tcase are also new from Toyota. There had been talk of turbo'ing the 1FZFE but that was still up in the air. A very nice low mile (around 100k) 2000 100-series was sourced as well. Our plan was to put the 100-series body on an FZJ80 chassis. We do have a 1997 FZJ80 nice and clean rust free chassis for the build here at the shop. About $60k in OEM Toyota parts were sourced to do the build, that does not include the cost of the 1FZFE long block.
Make no mistake, this is a PROJECT. The 105 needs to be built. We would like to sell this as a package deal because it is easier for everyone involved. We will see how that goes before considering breaking things up. By far the best value here is in buying the package deal but I guess you have to want an FZJ105. We are ready to go here at my shop to build the Cruiser for you, I can give you a rough idea on what that will cost labor wise. Since we had planned out the build we are well versed on how it should and would unfold.
Rare opportunity here to get a LHD 105-series. I am sure we will begin to see these imported over the next few years but not many will be LHD and none will have all these new OEM parts and assemblies.
Here is the quick and dirty listing of what we have for the project, all parts are new OEM Toyota unless otherwise noted.
-2000 UZJ100, low mile at around 110k. River Rock Green Mica
-1997 FZJ80 donor chassis, no title
-New OEM from Toyota 1FZFE coil pack long block - 240hp and 300ftlbs stock
-All related engine parts, coil packs/manifolds and so forth
-H151 5spd trans
-HF2A full time tcase
-All wiring harness to convert a UZJ100 to a FZJ105. $10k in OEM wiring harnesses that were not easy to source.
-Interior bits for the manual trans conversion, console surround, ect.
-Poverty Pack exterior trim bits
-Front and rear 80/105 axle housings.
-FZJ105 gague cluster.
I will update this with pictures and a better listing of parts as I can. Currently not parting this out!
Let's start this at $70,000
and I can tell you that is far less than what the owner has in it all.
Pm me, email me at ian@snlandcruisers.com and as I mentioned I am sure the owner will chime in here so you can communicate with him as well.
Cheers
@gonzopancho you need the drivetrain from this setup for something I’m sure
I’m sure, but the only stock displacement 1fz engines I have are the one in my 40 (which is a coilpack and has a NIB Katzuma (TRD oem) supercharger on it with the h55f, split case and locked / disc axles from my hdj75 (yes, I changed the input shaft) and the wits end turbo US model that is in my 62 on locked 80 chassis project.
The others (a “1fz-f” for the 66 FJ45LV and another coilpacked 1fz-f with another supercharger for the stretched 63 fj40) are both getting a 5.2L stroke with better rods.
Incoming parts listing, round 1!
19000-66120 Engine Assy. x1
23209-66010 Fuel injector x6
90116-10169 Exhaust mani studs x13
90179-10037 Exhaust mani nuts x13
17141-66020 Exhaust manifold x1
17142-66010 Exhaust manifold x1
90126-08008 Intake mani studs x4
19968-66010 Ign. bracket x1
90919-01192 Spark plugs x6
90919-00191/2/3/4/5/6 Ign. wires x6
90919-02232 Ign. coil x3
58804-60110 Panel shifter x1
47110-66060 Support Assy. brake x1
55107-60160 Support Assy. clutch x1
31301-60220 Pedal, sub Assy. x1
33530-60380 Lever Assy. transmission x1
36331-60090 Boot, transfer shifter x1
36360-60620 Lever Assy. transfer x1
36344-60030 retainer transfer x1
36321-60420 Lever, transfer x1
33554-60081 Cap shift lever x1
90250-10192 Pin straight x2
90913-01021 Bolt flywheel x10
36327-60130 Shaft transfer x1
36331-60080 Boot transfer shift x1
33584-60050 gasket control shift lever x1
36324-60060 Bush transfer shift x2
36324-60070 Bush transfer shift x4
36303-60161-C0 Knob transfer shift x1
36331-60040 Boot transfer shift x1
36362-60060 Lever transfer x1
90404-51237 union x1
94531-00800 washer x2
36345-60020 gasket transfer x4
36345-60010 gasket transfer x1
90254-05002 pin x1
91611-60830 bolt x4
33281-16020 pin lever lock x2
17168-66020 insulator exhaust x1
17167-66040 insulator exhaust x1
90467-20002 clip x2
16385-17010 slider fan belt x1
95333-06040 hose x1
95333-06010 hose x1
90480-18001 gourmet pcv x1
90206-18002 washer x1
90253-11001 pin ring x2
12204-66020 valve pcv x1
11291-66010 plate 1FZFE x1
11296-27020 label engine x1
90301-73004 O-ring x1
12180-13010 cap x1
90179-12024 nut x2
90179-12090 nut x2
12361-17011 engine mount x2
12361-17070 engine mount x2
51401-60040 bracket engine mount x1
12381-66020 stabilizer engine x2
12381-66010 stabilizer engine x2
16371-66020 pulley fan x1
44360-60200 reservoir power steering x1
16381-66030 bar fan belt x1
23807-66030 pipe fuel x1
17177-66040 gasket intake x1
27060-66090 Alternator Assy. x1
44320-60182 pump power steering x1
28100-66060-84 Starter remanned x1
44411-60520 hose power steering high press x1
44360-60171 reservoir assy power steering x1
78180-60600 throttle cable x1
16278-66011 pipe water bypass x1
31410-60600 clutch master cylinder x1
78120-60200 throttle pedal x1
83420-16040 water temp sensor x1
89422-35010 sensor x1
Cheers
Parts listing round 2!
31415-10010 gasket x1
89615-60010 sensor x2
44372-30030 gasket x1
90467-16031 clip x2
96133-41500 clip x2
90467-21010 clamp x2
90430-12221 gasket x1
47264-60020 clevis x1
90280-05008 keyway x1
44316-60020 gear p/s pump x1
89424-12010 sensor air x1
31230-60181 bearing assy clutch x1
47201-60720 ADVIOS brake master cylinder x1
44610-6A060 ADVIOS brake booster x1
44785-60010 gasket brake x1
19941-66010 clamp cord No1 x1
19947-66010 clamp cord No4 x1
90464-00555 clamp x1
23280-75010 fuel press reg. x1
12261-66030 hose vent x1
96132-51100 clip hose x1
23801-66030 pipe fuel x1
23300-50110 fuel filter x1
90561-08020 spacer x4
19942-66010 clamp cord No2 x1
90464-00556 clamp x1
19539-16010 holder resistive x6
23207-20011 damper fuel x1
22271-66020 gasket throttle x1
12262-66030 hose vent x1
19946-66010 clamp cord No3 x1
90917-11037 filter gas x1
96135-51100 clip hose x2
90430-T0003 gasket x1
90469-12012 clamp x1
17173-66020 exhaust mani gasket x1
17198-66010 exhaust mani gasket x1
17171-66020 intake mani gasket x1
16470-66030 radiator overflow bottle assy x1
22210-66070 throttle body x1
12511-66010 Alternator bracket x1
48825-60040 bracket sway bar x2
48516-60031 bracket rear shock x2
48310-60030 front bump stop assy x2
17111-66040 lower intake manifold x1
17190-66030 upper intake manifold x1
31250-0w031 disc clutch x1
31210-0w032 clutch cover x1
13405-66030 flywheel x1
41101-60091 carrier x1
41301-60080 carrier x1
41311-60060 case diff x1
33030-6A310 transmission assy x1
41101-60180 carrier x1
36120-60241 transfer case assy x1
48313-60010 rear bump stops x2
48257-60020 insulator coil spring x2
43209-60050 hose axle breather x1
16400-66131 radiator assy x1
82733-60031 block cowl x1
17894-66010 resonator intake x1
17893-66020 resonator intake x1
17881-66100 hose air cleaner x1
90987-02006 relay x3
90982-09013 fuse 30amp x10
28300-46010 relay starter x1
86530-20070 relay horn x1
82620-60010 block assy fusible x1
84725-60020 diff lock switch x1
91511-c0835 bolt x3
90982-09011 fuse 20amp x10
96111-10560 clamp x1
96111-10850 clamp x1
96111-10900 clamp x1
37140-60500 shaft assy x1
37110-6A620 shaft assy x1
17401-66131 pipe sub assy x1
84013-60010 panel sub assy x1
84012-60031 control panel x1
87910-60801-C0 mirror assy x1
87940-60840-C0 mirror assy x1
55404-60120-C0 panel sub assy x1
To be continued tomorrow...
Cheers
Round 3 of parts listing, final round!
37140-60500 front driveline x1
37110-6A620 rear driveline x1
82221-60050 wire oil press. x1
82125-60442 wire transmission x1
82141-60312 wire instrument x1
82121-6A041 wire engine x1
82136-60743 wire dash/cowl x1
82620-60030 fuse block x1
82112-60245 wire engine #2 x1
89533-60230 4wd ECU x1
23080-50061 fuel resistor assy. x1
82720-60070 fuse block x1
55223-60232 firewall insulator pad x1
17700-66182 Air cleaner assy. x1
55670-60070 dash vent x1
55660-60130 dash vent x1
90468-04177 clip dash trim x4
90010-05104 bolt x2
84999-70007 bulb dash x8
84731-60010 HVAC knob x1
55897-60010 HVAC knob x1
81731-20192 non-US front fender lights x2
75744-60010-H2 exterior side trim x1
75743-60010-H2 exterior side trim x1
75612-60120-H2 exterior side trim x1
75611-60120-H2 exterior side trim x1
75731-60120-H2 exterior side trim x1
75732-60120-H2 exterior side trim x1
75652-60170-H2 exterior side trim x1
75651-60180-H2 exterior side trim x1
75741-60160-H2 exterior side trim x1
75742-60160-H2 exterior side trim x1
75743-60020 emblem x1
42181-60070 diff gasket x1
31230-36210 clutch bearing x1
43232-60031 trunnion bearing cap x2
90942-02052 lug studs x12
43233-60030 trunnion shim x2
43235-60020 trunnion shim x2
90521-34005 snap ring x2
45721-60080 steering bracket x1
90901-05002 ring gear bolt x12
90942-02049 lug stud x12
48306-60062 rear frame bump stop x2
41204-35080 diff flange x1
41204-60050 diff flange x1
90366-50007 bearing x1
90366-40088 bearing x1
90366-50177 bearing x1
90366-30071 bearing x1
90363-15017 bearing x1
41371-36011 diff spider x1
41341-55013 diff spider gear x4
41231-60030 spacer pinion x1
90311-38047 seal x1
41331-35011 gear x2
41331-60060 gear x2
41315-30010 diff nut adjust x2
41341-35020 spider gear x4
41315-35020 nut adjust x2
41231-24010 spacer pinion x1
90345-53020 plug knuckle x2
41351-60010 washer diff x4
41214-60010 slinger x1
41214-26010 slinger x1
41316-0C010 lock diff adjust nut x2
41317-0C010 lock diff adjust nut x2
47491-22020 plug rear ebrake adjust x2
90119-08378 bolt x10
90250-06085 pin x1
42110-60452 rear axle housing x1
43110-60400 front axle housing x1
*USED PARTS*
HVAC panel assy. x1
FZJ105 Middle East spec complete vehicle wiring harnesses x1
FZJ105 Middle East spec gague cluster 83800-6A870 x1
FZJ80 steering box
1997 FZJ80 complete rolling chassis, non-diff lock axles.
Normally what we do with these builds is buy the stuff from the donor Cruiser (FZJ80) that is not needed in the build from the customer, store/sell ourselves. Still willing to do that but to us it is not worth more than $2000, the engine trans/tcase have 465,000 miles on them and are simply cores. Interior is well used.
Few things to mention before wrapping up the for sale ad. There is no ECU, a new or used one will need to be sourced. The gauge cluster is used, if it was my Cruiser I would try to find a new one. The reason there are some axle & diff parts is because that is what is left over after taking what we needed for another of Johns builds, an HDJ79. Originally we had for the 105 build front & rear axle shafts, knuckles and hubs + related parts, 105 brakes, 105 steering box, diff parts and 105 steel wheels but this was all used on Johns HDJ79 built. These parts bolt on 80/105 axle housings and convert it to five lug with stronger rear axle shafts and stronger hubs studs/dowels. Bigger front brakes as well. You can do this too but the parts will need to be purchased or use the 80 parts from the rolling chassis to keep it six lug. I don't think we planned to run ABS or rear LSPV on the 105 either so for example the brake booster/master is for non-ABS.
You can see the HDJ79 build over here to see the difference between 80/105 hubs, axles, ect.
That wraps up the for sale ad, any questions feel free to ask me.
Cheers
I believe we have a correction to make here. The tcase is not full time, not sure how I missed that but obviously it has no CDL. I didn't order 100% of these parts. I checked with Dave in Japan also and we both agree it is a part time tcase. From a 100/105-series.
Cheers
That would explain this then:
36303-60161-C0
So this would be a manual shift HF1A?
I do believe so yes. Which also means to use this tcase you will need to at the minimum fit free wheeling hubs to the donor 80 axles.
Or sell it and get a full time case if you like full time 4wd.
Cheers
I don’t curse in public but HOLY FAWK.
The effort to source every part here is out of this world.
Nobody goes full @jomelo like @jomelo.
