Round 3 of parts listing, final round!
37140-60500 front driveline x1
37110-6A620 rear driveline x1
82221-60050 wire oil press. x1
82125-60442 wire transmission x1
82141-60312 wire instrument x1
82121-6A041 wire engine x1
82136-60743 wire dash/cowl x1
82620-60030 fuse block x1
82112-60245 wire engine #2 x1
89533-60230 4wd ECU x1
23080-50061 fuel resistor assy. x1
82720-60070 fuse block x1
55223-60232 firewall insulator pad x1
17700-66182 Air cleaner assy. x1
55670-60070 dash vent x1
55660-60130 dash vent x1
90468-04177 clip dash trim x4
90010-05104 bolt x2
84999-70007 bulb dash x8
84731-60010 HVAC knob x1
55897-60010 HVAC knob x1
84013-60010 panel sub assy x1
81731-20192 non-US front fender lights x2
75744-60010-H2 exterior side trim x1
75743-60010-H2 exterior side trim x1
75612-60120-H2 exterior side trim x1
75611-60120-H2 exterior side trim x1
75731-60120-H2 exterior side trim x1
75732-60120-H2 exterior side trim x1
75652-60170-H2 exterior side trim x1
75651-60180-H2 exterior side trim x1
75741-60160-H2 exterior side trim x1
75742-60160-H2 exterior side trim x1
75743-60020 emblem x1
42181-60070 diff gasket x1
31230-36210 clutch bearing x1
43232-60031 trunnion bearing cap x2
90942-02052 lug studs x12
43233-60030 trunnion shim x2
43235-60020 trunnion shim x2
90521-34005 snap ring x2
45721-60080 steering bracket x1
90901-05002 ring gear bolt x12
90942-02049 lug stud x12
48306-60062 rear frame bump stop x2
41204-35080 diff flange x1
41204-60050 diff flange x1
90366-50007 bearing x1
90366-40088 bearing x1
90366-50177 bearing x1
90366-30071 bearing x1
90363-15017 bearing x1
41371-36011 diff spider x1
41341-55013 diff spider gear x4
41231-60030 spacer pinion x1
90311-38047 seal x1
41331-35011 gear x2
41331-60060 gear x2
41315-30010 diff nut adjust x2
41341-35020 spider gear x4
41315-35020 nut adjust x2
41231-24010 spacer pinion x1
90345-53020 plug knuckle x2
41351-60010 washer diff x4
41214-60010 slinger x1
41214-26010 slinger x1
41316-0C010 lock diff adjust nut x2
41317-0C010 lock diff adjust nut x2
47491-22020 plug rear ebrake adjust x2
90119-08378 bolt x10
90250-06085 pin x1
42110-60452 rear axle housing x1
43110-60400 front axle housing x1
*USED PARTS*
HVAC panel assy. x1
FZJ105 Middle East spec complete vehicle wiring harnesses x1
FZJ105 Middle East spec gague cluster 83800-6A870 x1
FZJ80 steering box
1997 FZJ80 complete rolling chassis, non-diff lock axles.
Normally what we do with these builds is buy the stuff from the donor Cruiser (FZJ80) that is not needed in the build from the customer, store/sell ourselves. Still willing to do that but to us it is not worth more than $2000, the engine trans/tcase have 465,000 miles on them and are simply cores. Interior is well used.
Few things to mention before wrapping up the for sale ad. There is no ECU, a new or used one will need to be sourced. The gauge cluster is used, if it was my Cruiser I would try to find a new one. The reason there are some axle & diff parts is because that is what is left over after taking what we needed for another of Johns builds, an HDJ79. Originally we had for the 105 build front & rear axle shafts, knuckles and hubs + related parts, 105 brakes, 105 steering box, diff parts and 105 steel wheels but this was all used on Johns HDJ79 built. These parts bolt on 80/105 axle housings and convert it to five lug with stronger rear axle shafts and stronger hubs studs/dowels. Bigger front brakes as well. You can do this too but the parts will need to be purchased or use the 80 parts from the rolling chassis to keep it six lug. I don't think we planned to run ABS or rear LSPV on the 105 either so for example the brake booster/master is for non-ABS.
You can see the HDJ79 build over here to see the difference between 80/105 hubs, axles, ect.
I guess that is pretty cold for North Florida. Hope you got good coolant in his Cruisers. I prefer dry cold vs wet cold myself. Cheers
forum.ih8mud.com
That wraps up the for sale ad, any questions feel free to ask me.
Cheers
