Builds Fujiwara's 3 linked super daily (15 Viewers)
Everybody makes a good point with the body mounted slider. But at this point, I think I value having the armor be a consumable that I can beat up and replace daily easily over the gains in performance. I’ll probably notch the rocker…. I kinda hammered it already, so I can gain a little more clearance with the sliders.l but that’s probably it
Replace daily 😂 :rolleyes:
Uuuuuhhhhhh I bought beadlocks… the reds gross but they were a good deal! They’ll get stripped and powder coated some other color before they’re mounted. I got what seems to be the last set of rear trail tailor springs. The icon springs that I have in the rear were unseating with the 6” dobinsons MRRs. I’m going from a 20” free height to a 23” free height. I’m kinda hoping I can run a full blown 12” shock with these, the dobinsons are only an 11” but idk if it totally make a difference and the roll steer is bad enough as is.
Sand hollow prep for may has begun and this was an expensive week
Run those bad boys! They’d look outstanding on your white rig.
Purple would B best... :smokin:
I need to go to Sand Hollow with you so you can teach a Old Guy how to wheel 😎
Your crew knows how to have fun !
Is this the bathroom version of bump stop tuning?
More stuff. The icon rear springs were unseating so I finally pulled the trigger on some 23” tall trail tailor springs
So you hate red wheels but like red springs??? Together they would look fantastic on your white Fugiwara.
I’m keen to see how much lift those springs give you, very similar specs to the 4” flexi from dobi
