fuel tank specs. (2 Viewers)
no.california S.F.O BAY AREA (EAST BAY)
i just filled up my gas tank for the first time since i got my cruiser,it nearly took 20 gals.of fuel.the gauge was showing close to empty before i filled up.i was wondering what is the exact amount this tank holds.thanks again ppl. john:)
i think i put 22.5is gallons in my 60 before and in marks 62 it took 22.45ish gallons when i filled up for the drive south to deliver it to him (it was on fumes as was mine) so i would say they are 23 gallon tanks... (someone correct me if i am wrong) on a regular basis my truck takes around 18-19 gallons when i fill up.
IIRC its 23.8 gallons. You do need to get used to how your fuel guage reads. I would always fill mine up at around the empty line and it would take 17 to 18 gallons. I once ran it about an 1/8 below the empty mark and only put in 21 gallons. One day I am going to fill up a jerry can and run it empty to see how low it will go on the guage. Moral of the story is you can go way past empty on most of these trucks.
~23gallon / 90L
look in your land cruiser handbook in the glove box, the specs are in there
He was asking for specs not how much you put in when its on empty
Model
FJ62
Manufacturer
Toyota/TLC
Years Available
1988-1990
Body Style
4-Door Wagon
Seating Capacity
Five to Seven
Drivetrain
Front Engine, 4x4
Engine
4.0 liter OHV Inline 6 cyl.
Fuel System
Electronic Fuel Injection
Horsepower
155 @ 4000 rpm
Torque
220 ft-lbs. @ 3000 rpm
Transmission
ECT 4-Speed Automatic
Wheelbase
107.5 in.
Length
184.0 in.
Width
70.9 in.
Height
68.9 in.
Track, F/R
58.5/57.9 in.
Cargo Storage
98 cu. ft.
Towing Capacity
3500 lbs.
Suspension
Semi-Elliptical Leaf Springs
Brakes, F/R
Power Ventilated Disc/Drum
Curb Weight
4480 lbs.
Clearance
8.1 in.
Fuel Capacity
23.8 gal.
MPG Estimate
12/19
Here is a 60
Model
FJ60
Manufacturer
Toyota/TLC
Years Available
1981-1987
Body Style
4-Door Wagon
Seating Capacity
Five to Seven
Drivetrain
Front Engine, 4x4
Engine
4.2 liter OHV Inline 6 cyl.
Fuel System
Carbureted
Horsepower
135 @ 3600 rpm
Torque
210 ft-lbs. @ 1800 rpm
Transmission
4-Speed Manual
Wheelbase
107.5 in.
Length
184.0 in.
Width
70.9 in.
Height
69.5 in.
Track, F/R
58.5/57.9 in.
Cargo Storage
98 cu. ft.
Towing Capacity
3500 lbs.
Suspension
Brakes, F/R
Curb Weight
4246 lbs.
Clearance
8.1 in.
Fuel Capacity
23.8 gal.
MPG Estimate
11/18
Model
FJ62
Manufacturer
Toyota/TLC
Years Available
1988-1990
Body Style
4-Door Wagon
Seating Capacity
Five to Seven
Drivetrain
Front Engine, 4x4
Engine
Fuel System
Horsepower
155 @ 4000 rpm
Torque
Transmission
Wheelbase
107.5 in.
Length
184.0 in.
Width
70.9 in.
Height
68.9 in.
Track, F/R
58.5/57.9 in.
Cargo Storage
98 cu. ft.
Towing Capacity
3500 lbs.
Suspension
Brakes, F/R
Curb Weight
4480 lbs.
Clearance
8.1 in.
Fuel Capacity
23.8 gal.
MPG Estimate
12/19
ok:)
First time I read that I thought it was wrong because mine would be on empty and I could only get in about 18 gallons. Finally realised it was the guage. I can and have gone way past empty( lots of space between the needle and the e mark) and only put in 22 gallons.
thanks to all of you,rekcut thanks for the detailed info.now i know how far i can go on an empty gauge not empty tank,haha. john
