Have you checked that your lines / connections are all good from tank to filter to pump to carb? I just went through some similar issues...I checked all the same things as you and ended up finding a pinhole leak in the hard fuel line where it runs along the frame (passenger side below the tank). The fuel evaporates quickly so I hadn't noticed it leaking when sitting. A cheap test to rule out everything tank to pump is running a soft line from your pump to a gas can in the cab, although suggest test driving that in a safe place. Good luck.
