Coolerman
- Joined
- Jan 5, 2004
- Threads
- 143
- Messages
- 6,766
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
Doing a bit of research on fuel line clamps.
Types
Worm Drive: Cheap. These are the the slotted worm drive clamps that are available by the back at Auto Crap, always give you a cut because of the end sticking out, and they have a tendency to cut the hose when tightened too tight. Hard to remove in tight places. Ugly as sin.
Worm Drive: Expensive. Rolled edges so won't cut hose as easily. No exposed end. Good clamp. Also hard to remove. Still ugly.
T-Bar Clamp: Expensive. Similar to the OEM Toyota wire clamps but uses a band instead of wire. No exposed end. Easy to remove and re-install as you don't have to completely unscrew it. More OEM looking.
Plastic ZIP TIES: Yes, zip ties. Found out that Evinrude uses them on boat motors for all the fuel lines. (This makes so much sense I'm going to try it. ) Make sure to use the metal locking type that are UV stable.
Wire Spring Clamps: Cheap. Easy to install and remove but will cut into the line if they are the wrong size. Not for high pressure. (4 psi should be fine)
Wire Spring Bands: Cheap. Used by a lot of OEM's. Easy to install/remove/. Look OK.
Permanent Crimped clamps: Cheap clamps but requires a crimping tool. These look totally clean but are not easily removed.
Pros/cons?
Types
Pros/cons?
